HDR400 vs HDR10
HDR400 is a VESA standard for the expected peak brightness of a screen. It basically helps consumers figure out how "good" a panel is by a simple measurement of peak brightness in HDR mode. There is HDR400, HDR600, and HDR1000. The higher the number, usually the better the HDR experience. Before this, there was no standard method of determining brightness and comparing between displays. Manufacturers could report whatever they wanted in the brightness measurements. And technically they still can. But unstandardized testing would mean they cannot use the HDR400/600/1000 logos and advertise it. So if you do not see these logos advertised on a product, then the brightness claims might be determined in a different way that could bump up the numbers.
HDR10 is an HDR standard. It is not a measurement of anything the television can produce. HDR10 is a free alternative to Dolby Vision HDR. These are standards that panels can support... a simple yes or no. Most monitors only support HDR. Dolby Vision is typically found on higher end television products from LG and Sony. No, not Samsung. HDR10+ is another standard that is supposed to mimic Dolby Vision a little better, but I have not seen a huge differentiation between HDR10 and HDR10+ in terms of content.
