Could someone help me build a pc
Go to solution Solved by podkall,
6 minutes ago, Kamboompoo said:
I have room to go a few hundred dollars above 1500$ if needed. But thank you for all the help for everyone
More would get you nicer aesthetics, and higher quality parts,
this list is the same but has faster and slightly better SSD and higher quality PSU:
PCPartPicker Part List
CPU: AMD Ryzen 7 7800X3D 4.2 GHz 8-Core Processor  ($384.00 @ Newegg)
CPU Cooler: Thermalright Phantom Spirit 120 SE 66.17 CFM CPU Cooler  ($35.90 @ Amazon)
Motherboard: MSI PRO B650-S WIFI ATX AM5 Motherboard  ($139.00 @ MSI)
Memory: Silicon Power Value Gaming 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  ($97.97 @ Amazon)
Storage: Acer Predator GM7000 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($129.99 @ Amazon)
Video Card: XFX RX-79GMERCB9 Radeon RX 7900 GRE 16 GB Video Card  ($540.53 @ Amazon)
Case: Montech AIR 903 MAX ATX Mid Tower Case  ($75.00 @ Amazon)
Power Supply: Corsair RM750e (2023) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($99.99 @ Amazon)
Total: $1502.38
Generated by PCPartPicker 2024-04-16 13:00 EDT-0400
I am new to building a PC and have a budget of 1500 dollars, and I’m in the U.S.
i want to play games mainly FPS and RTS and maybe video editing in the future.
I don’t have a current PC at the moment
if anyone can help thank you.
Edited by Kamboompoo
https://linustechtips.com/topic/1566937-could-someone-help-me-build-a-pc/
[ Moved to New Builds and Planning ]
What games do you want to play?
What country do you live in?
What's your budget?
What's your current computer, and do you want to reuse any of its parts?
19 minutes ago, Kamboompoo said:
I am new to building a PC and have a budget of 1500 dollars. I don’t know where to start looking
i want to play games and be able to do video editing
https://pcpartpicker.com/list/HwpbHG not best but i tried
PCPartPicker Part List: https://pcpartpicker.com/list/QsgLgB
Motherboard: MSI B650 GAMING PLUS WIFI ATX AM5 Motherboard  ($169.00 @ MSI)
Storage: Silicon Power UD90 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($102.97 @ B&H)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  ($499.99 @ Best Buy)
Power Supply: Corsair RM750x (2021) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($109.99 @ Amazon)
Total: $1474.82
Generated by PCPartPicker 2024-04-16 10:12 EDT-0400
Any questions about the build feel free to ask!
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3)
Total: $1474.82
Switch that psu out for a slightly cheaper one and you might be able to fit in a 7900gre by the skin of your teeth
PCPartPicker Part List: https://pcpartpicker.com/list/TtYrQP
Power Supply: Deepcool PM750D 750 W 80+ Gold Certified ATX Power Supply  ($79.98 @ Amazon)
Total: $1485.35
Generated by PCPartPicker 2024-04-16 10:34 EDT-0400
You're not wrong 😋
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Total: $1485.35
You're not wrong 😋
Just what I was thinking lol
PCPartPicker Part List: https://pcpartpicker.com/list/ChNNwg
Motherboard: ASRock B650 LiveMixer ATX AM5 Motherboard  ($149.99 @ Newegg)
Memory: PROXMEM UNDERWORLD TUF 32 GB (2 x 16 GB) DDR5-6400 CL32 Memory  ($96.99 @ Amazon)
Power Supply: Corsair CX750M (2021) 750 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($74.99 @ Best Buy)
Total: $1460.37
Generated by PCPartPicker 2024-04-16 10:35 EDT-04
Is there a microcenter nearby? There are some great deals
CL32
30
is Teamgroup MP44L out of reach?
C tier PSU with a high end GPU?
current PC:
PC configs I used before:
1 minute ago, podkall said:
30
First response time is same bruv
Believe so to keep it sub 1500, unless he’s doing specific stuff it won’t change too mcuh
People obsess over that tier list too much. It’s an important indicator, I agree, but with the ~200w of space it’ll be fine with surges. You also have to keep in mind budget. If it was d tier/e tier /f-tier then no, but above that system killers don’t really exist. I get the worry, but there’s a balancing act with budget
Needing peripherals then ?
first response doesn't mean much when the latency is higher,
I guess with headroom it'll be okay
current PC:
sometimes it's the small things that can make it worth,
as much as some components aren't important, I'm not really feeling right when you pair high-end parts with the cheapest SSD possible:
Storage: Western Digital Blue SN580 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  ($113.99 @ Newegg)
Power Supply: MSI MAG A750GL PCIE5 750 W 80+ Gold Certified Fully Modular ATX Power Supply  ($89.00 @ Amazon)
Total: $1475.39
Generated by PCPartPicker 2024-04-16 11:44 EDT-0400
current PC:
13 minutes ago, Linuswasright said:
With the higher mhz shouldn’t it start to balance out?
yeah, but memory controller strain, each increase above 6000 sweetspot is kind of a gamble
current PC:
Tbh,there won’t be many massive gains past where we are right now till ~2000$ mark
That is, unless, you live by a microcenter
Total: $1502.38
current PC:
current PC:
