PC for machine learning and gaming?
On 4/15/2024 at 10:43 AM, podkall said:This could be a decent build that could probably handle 3070Ti, idk how the prices are in Poland but I used Germany prices so it should be close:
- if u dont mind running stock cooler, that's also possible to save ~20€
- You can use your case, all required is parts fitting physically inside case (gpu, cpu cooler)
- Same with RAM, preferred speed is CL16-18 (lower is better) and 3200-3600Mhz
- MP44L is cheaper in Germany than Lexar 710, another decent SSD would be WD Blue SN580 which is also cheaper than 710 Lexar based on Germany prices (Blue SN580 is actually overall better than both other mentioned SSDs)
- Any other questions I can answer
- Motherboard almost same dirt you have, if you want recommendation for cheapest MB that could handle faster CPUs than 5600 for potential upgrades let me know
- Get 5600, 5600x is almost same CPU with more unlocked voltage and higher base clocks, but they are almost identical
- The PSU is not my favourite to pair with 3070Ti, but should work without exploding
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor (€108.00 @ Mindfactory)
CPU Cooler: Deepcool AG400 75.89 CFM CPU Cooler (€24.90 @ Alza)
Motherboard: Asus PRIME B450M-K II Micro ATX AM4 Motherboard (€51.60 @ Amazon Deutschland)
Memory: *G.Skill Aegis 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory (€37.90 @ Alza)
Storage: TEAMGROUP MP44L 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive (€124.46 @ Galaxus)
Case: Montech X3 Mesh ATX Mid Tower Case (€54.90 @ Alza)
Power Supply: be quiet! System Power 10 650 W 80+ Bronze Certified ATX Power Supply (€60.83 @ Amazon Deutschland)
Total: €462.59
Generated by PCPartPicker 2024-04-15 10:42 CEST+0200
similarly fast are also 2080Ti and 4070 if you can possibly find those for cheaper
Thank you for this ^ . I'm gonna look into it.
