Why such a difference? 24-25" monitors vs 27"+ monitors
Twinsenito
So I'm a long time user of 24-25" monitors on my PC. The case is: my space for PC is limited so I prefer to have more monitors in my multimonitor setup instead of having less of these but the bigger ones or the higher resolution ones. First and foremost for the productivity and multi-window purposes. So I have 3 24" monitors instead of 2 27" ones.
The case is: almost all the bells and whistles that are being developed for monitors are only available on monitors of 27" size or above. For sure, you can get a high refresh rate 24" monitor. But that's pretty much it. What if I want to have a brightness higher than 400 nits? No options at all. MicroLED? MiniLED? Local dimming? QLED? QD-OLED? OLED? HDR? Brightness above 400 nits? Thunderbolt connectivity? All of that is missing on the monitors smaller than 27".
So I wonder why.... I would be happy to buy these but there are just no options at all - at any prices. It is aspecially weird when you concider the fact that they are re-releasing the same stuff over and over again on 27"+ displays. But 24-25" are concidered to be budget displays I guess?.. What are your thoughts on that matter? Why is that the case? Why there is such a huge difference between 27"+ displays vs. 24-25" displays?
I am not a native English speaker, so I might make some mistakes here and there. I am sorry in advance for that. I do my best to write as good and clean as I can. Cheers!
I feel as though, for most people a dual monitor setup is fine, 3s start to get into excess and as a large amount of setups are gaming based (probably more prominently here and for the "gaming PC" market) then youd generally want a large high quality display as youre first and foremost and for the secondary, for some people, so long as it has a screen, its fine. I know myself i was running with a 27" 165Hz 1080p monitor for a while and my secondary i only set to 60Hz (could go higher but didnt really need it) and was 24-25" i cant remember
Now ive got a 27" 1440p with HDR and 170Hz refresh rate with a few other bells and whistles over my old main monitor, which is now my secondary.
So in all cases where ive had a dual monitor setup, my main (that displays the game) has been a higher quality monitor that will display the game nicely, whereas the secondary is for other tasks, background youtube, discord, random googling etc so doesnt need to be as "fancy" so to speak
To sum up what im saying, i reckon the vast majority of people only really see the need for 2 monitors, and so 2 27" monitors are more beneficial to them as they dont need the desk space 3 monitors would take up and would instead prefer the extra size
System specs:
GPU: Sapphire AMD Radeon RX 7800 XT NITRO+ [1050mV, 2.8GHz core, 2.6Ghz mem]
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Just now, TatamiMatt said:
I feel as though, for most people a dual monitor setup is fine, 3s start to get into excess and as a large amount of setups are gaming based (probably more prominently here and for the "gaming PC" market) then youd generally want a large high quality display as youre first and foremost and the for the secondary, so long as it has a screen, its fine. I know myself i was running with a 27" 165Hz 1080p monitor for a while and my secondary i only set to 60Hz (could go higher but didnt really need it) and was 24-25" i cant remember
Feels like it. It may be that my situation is just very unique and niche, so there are no offers with any 'premium' tech at all. It's just a bit weird that there are no attempts from the tech developers to implement anything to 24" options - at all.
If it's 1440p it's probably because of the "sweetspot for 1440p" everyone talks about, where 27" is just the sweetspot for 1440p in terms of pixel density at that screen size.
Since "everyone" is following and recommending this sweetspot, it is expected that companies might pick up on that, and make more monitors in that sweetspot size.
I'd assume the 27" compared to 24-25" could have ergonomic benefits as well, for example a bigger monitor that displays bigger image and text let's you sit farther away from the screen. Which is slightly healthier for the eyes I'd assume.
Feel free to ask any questions regarding my comments/build lists. I know a lot about PCs but not everything.
PC:
Ryzen 5 5600 |16GB DDR4 3200Mhz | B450 | GTX 1080 ti
PCs I used before:
Pentium G4500 | 4GB/8GB DDR4 2133Mhz | H110 | GTX 1050
Ryzen 3 1200 3,5Ghz / OC:4Ghz | 8GB DDR4 2133Mhz / 16GB 3200Mhz | B450 | GTX 1050
Ryzen 3 1200 3,5Ghz | 16GB 3200Mhz | B450 | GTX 1080 ti
Again, you're just a niche customer. Companies aren't gonna invest millions into a customer base who's market cap is like 1 million. Guaranteed loss. 32'' 4k 240HZ OLED niche customers finally had a win this year when they're getting monitors they've been wanting. Doubt you'll win this waiting game however.
Desktop: Ryzen 7 5800X3D - Kraken X62 Rev 2 - STRIX X470-I - 3600MHz 32GB Kingston Fury - 250GB 970 Evo boot - 2x 500GB 860 Evo - 1TB P3 - 4TB HDD - RX6800 - RMx 750 W 80+ Gold - Manta - Silent Wings Pro 4's enjoyer
SetupZowie XL2740 27.0" 240hz - Roccat Burt Pro Corsair K70 LUX browns - PC38X - Mackie CR5X's
Current build on PCPartPicker
yeah supply/demand, which is what I've covered in my comment
PC:
PCs I used before:
21-24" is mostly bussiness stuff these days with most consumers going to 27 inches. All these fancy image stuffs are aimed at consumers and not bussinesses as they just dont have a use for it.
We also have the bigger numbers better that has always been happening and by this point sub 27 inch is seen as inferior for gamers for some reason. Its not at all but oh well.
not to mention the biggest market for the 22" - 24" market is in the office.  there's not many drones out their on their Dells or HPs that NEED 165Hz OLED panel @1000+nits
Edit:
Ninja'd lol
 With all the Trolls, Try Hards, Noobs and Weirdos around here you'd think i'd find SOMEWHERE to fit in!
24" 1080p still looks super sharp imo
@Twinsenito  Don't forget to show us your setup at some time here:
1440 24 inch was peak. Didnt even need AA which meant back then (2015 or before when msaa was as good as it got) that you'd lose less performance most of the time. Loved using a 24 inch 1440p benq for a little while but that stuffs basically gone extinct. Think aoc has one for sale still?
There's just one gaming one from Lenovo but yea, seems to be a professionals only customer base these days who needs screen real estate at all costs.
Why don't you just like... get ONE ultrawide that is substandard? Say 40 inches or so. That's going to be pretty wide and would probably knock your ball out of the court. Wouldn't %200 murder the budget like an OLED would, either.
you can sit farther away from screen, and posture is arguably important even when gaming for consistency
PC:
PCs I used before:
24" are considered small monitor size and anything for bigger experience or multi-monitor generally go larger as they tend to also be further.
Before I wanted certain spec in 24" mainly for shooters so I don't need to look around much but 27" started to gain more traction for a while.
27" is just a decent upgrade and in multi-monitor setup it will look good. Also higher resolution option.
But productivity wise 32" is also great really, 4K and more screen real estate, yes costs more so depends what work or need for it is important to one.
Personally for productivity I find 24" 1080p just bad, also reading text and looking at detail is a real pain.
So really in that size don't expect an HDR monitor, no market for it. There are higher resolution options for more fine detail though which for productivity is great.
I guess you can check list here too to filter specs. https://www.displayninja.com/hdr-monitor-list/
| Ryzen 7 7800X3D | AM5 B650 Aorus Elite AX | G.Skill Trident Z5 Neo RGB DDR5 32GB 6000MHz C30 | Sapphire PULSE Radeon RX 7900 XTX | Samsung 990 PRO 1TB with heatsink | Arctic Liquid Freezer II 360 | Seasonic Focus GX-850 | Lian Li Lanccool III | Mousepad: Skypad 3.0 XL / Zowie GTF-X | Mouse: Zowie S1-C | Keyboard: Ducky One 3 TKL (Cherry MX-Speed-Silver)Beyerdynamic MMX 300 (2nd Gen) | Acer XV272U | OS: Windows 11 |
5 hours ago, Twinsenito said:
most likely a demand issue,
1080p is about 20% of the market last i checked. You are the first person i've seen that's asking for a 24inch oled/hdr.
IIRC there were 1440p 24inch panels that were designed but no demand for it, premium 1080p monitors likely fall into the same category.
For me personally i prefer my main display to be 4k, as small as they can make it (my perfect monitor also doesn't exist), i'd use 1080p and 1440p monitor as text mons but that's about it. If there's a 24inch 4k monitor with all the bells and whistles i'd be interested but 27inch 4k oled is slated for 2025, there's no shot we are getting 24inch 4k of any kind.
the viewing experience of higher pixel density isn't something thats in demand, so i just settle for whats available. Most people sit alot further away.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
Fewer and fewer people are buying 24" monitors. And those that are aren't willing to spend much on them. Therefore the manufacturers aren't making good/expensive ones.
Dual setup is more common than triple. And I of those triple monitors I see, it seems more common now to have one of them being above the two others.
“Remember to look up at the stars and not down at your feet. Try to make sense of what you see and wonder about what makes the universe exist. Be curious. And however difficult life may seem, there is always something you can do and succeed at.
It matters that you don't just give up.”
-Stephen Hawking
On 4/5/2024 at 5:39 PM, Twinsenito said:
So I wonder why
In my opinion, the sweet screen size is 27" for Wide screen. It look perfectly fine in 100% scaling for 1440p.
Anything bigger than 27" is different story and most people do find it a bit too big.
24" is too small and I would never go back into 24" and most people once used 27" is hardly going back as well.
PC: AMD Ryzen 9 5900X, Gigabyte GeForce RTX 4090 OC 24G, X570 AORUS Elite WIFI Motherboard, HyperX FURY 32GB DDR4-3200 RGB RAM, Creative Sound Blaster AE-9 Sound Card, Samsung 970 Evo Plus M.2 SATA 500GB, ADATA XPG SX8200 Pro M.2 SATA 2TB, Asus HyperX Fury RGB SSD 960GB, Seagate Barracuda 7200RPM 3.5 HDD 2TB, Cooler Master MASTERLIQUID ML240R ARGB, Cooler Master MASTERFAN MF120R ARGB, Cooler Master ELV8 Graphics Card Holder ARGB, Asus ROG Strix 1000G PSU, Lian Li LANCOOL II MESH RGB Case, Windows 11 Pro (22H2).
Laptop: Asus Vivobook "A Bathing Ape" - ASUS Vivobook S 15 OLED BAPE Edition: Intel i9-13900H, 16 GB RAM, 15.6" 2.8K 120hz OLED | Apple MacBook Pro 14" 2023: M2 Pro, 16 GB RAM, NVMe 512 GB | Asus VivoBook 15 OLED: Intel® Core™ i3-1125G4, Intel UHD, 8 GB RAM, Micron NVMe 512 GB | Illegear Z5 SKYLAKE: Intel Core i7-6700HQ, Nvidia Geforce GTX 970M, 16 GB RAM, ADATA SU800 M.2 SATA 512GB.
Monitor: Samsung Odyssey OLED G9 49" 5120x1440 240hz QD-OLED HDR, LG OLED Flex 42LX3QPSA 41.5" 3840x2160 bendable 120hz WOLED, AOC 24G2SP 24" 1920x1080 165hz SDR, LG UltraGear Gaming Monitor 34" 34GN850 3440x1440 144hz (160hz OC) NanoIPS HDR, LG Ultrawide Gaming Monitor 34" 34UC79G 2560x1080 144hz IPS SDR, LG 24MK600 24" 1920x1080 75hz Freesync IPS SDR, BenQ EW2440ZH 24" 1920x1080 75hz VA SDR.
Input Device: Asus ROG Azoth Wireless Mechanical KeyboardAsus ROG Chakram X Origin Wireless MouseLogitech G913 Lightspeed Wireless RGB Mechanical Gaming Keyboard, Logitech G502X Wireless Mouse, Logitech G903 Lightspeed HERO Wireless Gaming Mouse, Logitech Pro X, Logitech MX Keys, Logitech MX Master 3, XBOX Wireless Controller Covert Forces Edition, Corsair K70 RAPIDFIRE Mechanical Gaming Keyboard, Corsair Dark Core RGB Pro SE Wireless Gaming Mouse, Logitech MK850 Wireless Keyboard & Mouse Combos.
Entertainment: LG 55" C9 OLED HDR Smart UHD TV with AI ThinQ®, 65" Samsung AU7000 4K UHD Smart TV, SONOS Beam (Gen 2) Dolby Atmos Soundbar, SONOS Sub Mini, SONOS Era 100 x2, SONOS Era 300 Dolby Atmos, Logitech G560 2.1 USB & Bluetooth Speaker, Logitech Z625 2.1 THX Speaker, Edifier M1370BT 2.1 Bluetooth Speaker, LG SK9Y 5.1.2 channel Dolby Atmos, Hi-Res Audio SoundBar, Sony MDR-Z1R, Bang & Olufsen Beoplay EX, Sony WF-1000XM5, Sony WH-1000XM5, Sony WH-1000XM4, Apple AirPods Pro, Samsung Galaxy Buds2, Nvidia Shield TV Pro (2019 edition), Apple TV 4K (2017 & 2021 Edition), Chromecast with Google TV, Sony UBP-X700 UltraHD Blu-ray, Panasonic DMP-UB400 UltraHD Blu-ray.
Mobile & Smart Watch: Apple iPhone 15 Pro Max (Natural Titanium), Apple Watch Series 8 Stainless Steel with Milanese Loop (Graphite).
Others Gadgets: Asus SBW-06D2X-U Blu-ray RW Drive, 70 TB Ext. HDD, j5create JVCU100 USB HD Webcam with 360° rotation, ZTE UONU F620, Maxis Fibre WiFi 6 Router, Fantech MPR800 Soft Cloth RGB Gaming Mousepad, Fantech Headset Headphone Stand AC3001S RGB Lighting Base Tower, Infiniteracer RGB Gaming Chair
