Ok so I recently bought an rtx 4070 super. I had a question about what determines how hot the vrms get. Vrm temps in game;
Forza horizon 5 4k max settings -vrm temp 78
Far cry 6 4k max settings- vrm temp 84
Resdient evil 3 4k max settings- vrm temp 92
Dead spake remake 4k dlss quality max settings- vrm temp 86
Palwolrd 4k high settings- vrm temp 84
Cyberpunk 4k performance dlss overdirve rt- vrm temp 80
The outliner here is resident evil.
https://linustechtips.com/topic/1564700-how-do-gpu-vrms-work/
It will depend on two factors: How much power is running through them (i.e. essentially how much GPU load is there?), and how much cooling do they get.
If they run under high load, but at the same time the cooler is running slower because the GPU core isn't getting as hot, that might result in them getting hotter, despite power draw being the same.
https://linustechtips.com/topic/1564700-how-do-gpu-vrms-work/#findComment-16366542
 Jumping on @Eigenvektors bandwagon here, what are the rest of the gpu temps youre seeing; gpu temp and gpu hotspot temp?
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
Case Fans: Fractal Prisma (120 x6, 140 x3) + 2x40mm fans
https://linustechtips.com/topic/1564700-how-do-gpu-vrms-work/#findComment-16366543
Gpu temp itself does not go above 73 degrees. Hot spot in the high 80's can peak in the 90's but usually stays in the high 80',s.
https://linustechtips.com/topic/1564700-how-do-gpu-vrms-work/#findComment-16366545
Well in all games gpu usage is 100 percent or close to 100 percent.
https://linustechtips.com/topic/1564700-how-do-gpu-vrms-work/#findComment-16366547
Sure, that's how the GPU is designed to operate. But 100% usage doesn't really mean 100% of the GPU's resources are used at their fullest.
It simply means that it wouldn't be able to process commands any faster than it currently does. But it doesn't mean the commands it does get use all parts of the GPU core. So power draw and heat output can vary, even when the reported load is the same.
For example a game that is using raytracing or DLSS is going to make use of other parts of the GPU core than a game that isn't. And these different parts may draw a different amount of power.
https://linustechtips.com/topic/1564700-how-do-gpu-vrms-work/#findComment-16366550
Moreso on a per game basis as youve detailed above
System specs:
Case: 5000D AIRFLOW
PSU: Corsair RM850e
https://linustechtips.com/topic/1564700-how-do-gpu-vrms-work/#findComment-16366551
What's the brand and actual model of your 4070s? GPU temps vs hotspot temp, on average have 10-15c difference. Meaning if the gpu temp is around 65c, then hotspot is 75-80c. If the cooling solution and thermal pads are good, it could be lower. While vrm temp should be around 5-10c higher than gpu temp on average. However, if the differences are higher than those. You might want to check your thermal pads.
Personally, what I would do is first install afterburner(if you haven't yet). Then regardless of what gpu or hotspot temp is, I will set fan speed to manual and at around 70-80% fan speed(even 100%). If the vram is cooling down, it doesn't mean that the issue is already resolved. It just means that the fan curve is following the gpu temp/hotspot. Since those two aren't as hot, the fans are also not ramping up. But it will still just a band-aid solution. I would suggest googling to see if there are other people with the same make and model having thermal pad issue, because that might explain what's going on with your gpu. You can also check how much power is being feed to the gpu and try undervolting.
https://linustechtips.com/topic/1564700-how-do-gpu-vrms-work/#findComment-16366587
You can load VRAM to max and still have very low temps everything depends how hard is pushed memory controller load that is very depends from game but push to 100% basically impossible even stress test can't do that. Memory controller load will be higher if you turn on ray tracing or path tracing. Btw do undervolt 4xxx series run stupidly high clocks that generate massive heats by default settings and you gain 2-3% better performance only depends on luck you can run 15-20C cooler save a lot power and almost no performance hit.  I undervolt mine 4070 Ti from 1100mV 2790 Mhz to 935mV 2610 Mhz and I basically have no performance lose average 2 FPS but now GPU run average 15C less and use ~80W less
https://linustechtips.com/topic/1564700-how-do-gpu-vrms-work/#findComment-16366759
It is an asus dual oc card. I have overclocked it. Reviews do talk about vrm temps on this caed being high but within safe operating parameters. Also, the parametersnyou have mentioned, the temps are not far off that except for one game, resident evil. I have not been too concernef about temps as I owned a gtx 1070 before that ran at 83 degrees with a hot spot in the 90'S. After this I had a founders edition rtx 3060 ti which ran between 78 and 80 degrees with a hot spot in the 90's. My only concern my residnlent evil made vram temps higher compared to many other games I have, even games like cyberpunk that I consider to be more demanding.
https://linustechtips.com/topic/1564700-how-do-gpu-vrms-work/#findComment-16367094
Thanks. Can I do the same for my 4070 super?
https://linustechtips.com/topic/1564700-how-do-gpu-vrms-work/#findComment-16367095
