4K Active signal resolution on 1440p monitor?
On 3/29/2024 at 12:23 PM, dinkostinko said:GPU Scaling has been turned off the entire time, yet text is still visibly blurrier on Display 2 than it is on Display 1.
I unfortunately have to use HDMI as the USB-C port does not have the bandwidth to support two 1440p monitors.
Turning on GPU Scaling defaults the resolution to 4K, and limits me to 30hz. How do I make it so I am outputting a 1440p signal over HDMI just like I am over Displayport?
Sounds like AMD is not implementing something correctly in their driver.
Download the Custom Resolution Utility here: https://www.monitortests.com/forum/Thread-Custom-Resolution-Utility-CRU
Select the 1440p monitor at the top, then select the CTA-861 extension block and click "Edit":
Select the TV Resolutions data block:
Delete all the 4K entries:
Click OK on everything, then restart the graphics driver using Restart64.exe
Then the 4K profile should be gone, and it should use 1440p.
