my aio is being a pussy again
aren332
i got a 4790k oc to 4.8ghz @1.325v, cache at 4.4ghz at 1.2v, dram at 1.65v, and the other day, i was getting temps in prime 95 of max about 90c. Today, i launch it, it goes up to 100c and throttles to like 4.2ghz.
During the time between those stress tests, I have not changed any settings. for both times I was running non avx, prime95 small ffts. Restarted the pc, still get the same issue. My room ambient temp stayed the same for when i got 90c and 100c. My cpu power draw according to msi afterburner at both times was 130 max, 127w avg.
The cooler is fully tighten, even thermal paste spread at both times
Ive had this happen to me before
My cpu is delidded with arctic mx-4 thermal paste
my cooler is a arctic liquid freezer ii 280 front mounted
Any fix or reasons for this?
First thing I would suspect is the pump. Has it gone bad? is the speed too low? Is there a trapped air bubble?
Primary PC:
i bought the aio 2 weeks ago, i can hear the water flow just as fast as before
What was the cause then?
5950X/3080Ti primary rig  |  1920X/1070Ti Unraid for dockers  |  200TB TrueNAS w/ 1:1 backup
reseating the aio, but I dont think this is the current issue since after just 2 days, nothing to it could have changed
You are running p95 at a static 4800MHz.. its gonna get warm. I got the same temps on my 3770K at 4700MHz 1.36v with a Le Grand Macho RT and TY-143.
AMD R9 5900X | Thermalright Phantom Spirit 120 EVO, T30,TL-C12 Pro
Asus Crosshair VIII Dark Hero | 4x8GB G.Skill Trident Z @ 3733C14 1.5v
Zotac 4070 Ti Trinity OC @ 3045/1496 | WD SN850, SN850X, SN770
Seasonic Vertex GX-1000 | Fractal Torrent Compact RGB, Many CFM's
Between the IHS and CPU die or between the IHS and cooler cold plate?
^^^ Also this, P95 smallFFT is no joke, it will pull some obscene numbers. You can run ASUS Realbench if you want a similarly beefy but less intense load.
Main PC
CPU: i9 7980XE @4.5GHz/1.22v/-2 AVX offset
Cooler: EKWB Supremacy Block - custom loop w/360mm +280mm rads
Motherboard: EVGA X299 Dark
RAM:4x8GB HyperX Predator DDR4 @3200Mhz CL16
GPU: Nvidia FE 2060 Super/Corsair HydroX 2070 FE block
Storage:  1TB MP34 + 1TB 970 Evo + 500GB Atom30 + 250GB 960 Evo
Optical Drives: LG WH14NS40
PSU: EVGA 1600W T2
Case & Fans: Corsair 750D Airflow - 3x Noctua iPPC NF-F12 + 4x Noctua iPPC NF-A14 PWM
OS: Windows 11
Mouse: EVGA X17
Keyboard: Corsair K55 RGB
Mobile/Work Devices: 2020 M1 MacBook Air (work computer) - iPhone 13 Pro Max - Apple Watch S3
Other Misc Devices: iPod Video (Gen 5.5E, 128GB SD card swap, running Rockbox), Nintendo Switch
It ran before perfectly fine at the same settings at 4800mhz, now it goes up to like 87c trying to open a game
both
6 minutes ago, aren332 said:
both
Thermal paste isn't great for CPU Die -> IHS, that's typically why people delid to begin with, in order to replace the original thermal paste with liquid metal. Given that + the load the temps don't sound too crazy. A little high for that voltage, I've run soldered chips at far higher voltages and similar clocks (4.7GHz) with much lower temps, but A) solder is better than most TIM and B) they were HEDT chips with a larger IHS and CPU die, and thus a lot more surface area to get heat out through.
Main PC
PSU: EVGA 1600W T2
OS: Windows 11
Mouse: EVGA X17
what i dont get is why did it used to run prime95 at 90c and all of a sudden, it runs 100c and throttles to 4.2ghz. 90c had the same exact settings, delidded, even thermal paste spread, same voltage and freq.
Try Linpack Xtreme 1.15, you can get it at TPU.
Select the stress test, select the 10GB load, and let it run as many times as you want.. it will pull all the power you have allowed.
That is not the problem, my cpu temps used to be 90 now they are 100c and throttling for no reason. Any fix? I dont care about any stress test, my cpu temps overall just got much higher like 15c, it goes up to like 90c opening games
Start over again. Take the lid off your CPU and do it over.
What is between the cores and the heat spreder? Mx 4?
No, this isn't a thing.  You don't measure an AIO by its "sound of water movement".
This.
And your title...  Don't go blaming an AIO for a 10 year old CPU sucking ass.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
As @freeagent said, redo your CPU and the AIO TIM. It may have pumped out, or something else.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
I just did that, no change in temps, still throttles just as much, even thermal paste spread between aio and ihs
In cinebench r23 it throttles to like 3.8ghz just like it did before.
when i took the lid off the cpu, the thermal paste on the die was spread unevenly. The middle of the die, had very little thermal paste, only the sides had some. So i dropped some thermal paste in the middle, put the lid back on, put the aio back on, but temps didnt change.
I can feel the aio pump, the tubes are vibrating for sure
Could this be because I tightened the cooler too much? I didnt tighten it that hard tho, I tightened it until i started feeling resistance.
Also I have a delidded i5 4570 which i practiced delidding before doing my 4790k, and I squeezed it as hard as I could with my fingers, but thermal paste spread on the die, after taking the lid off was even
How MUCH resistance?
finger tight
I also cleared cmos, just in case, still the same temps, and then applied the settings I had before:
core 1 - 48
core 2 - 48
core 3 - 47
core 4 - 46
cache - 44
core voltage - 1,325
cache voltage - 1,200
dram freq - 2133mhz
dram voltage - 1,650
dram timings - 11-11-11-30
Tighten it all the way?
Why would you tighten only finger tight, that makes no sense to me. You need pressure, that is why it is called mounting pressure.
With this mounting kit, not sure it makes a difference thermally because it's hard mounted. If it was a Galahad 240, or some other cooler with a mounting kit with springs to provide tension, that would definitely make a difference, but here? Finger tight could actually be good enough, but it's also subjective. With the OP stating that they turned it until they felt resistance, that's very subjective, and we have no idea what "resistance" is defined as here.
Edited by Godlygamer23
Minor grammatical adjustment.
