GTA 5 not working literally need HELP!!
1 hour ago, Blazepoint5 said:Okey belive me if i told you this GTA 5 has been giving me issues like since i started playing it, i get error because the game wont launch. I have been getting this thing since when i use to play it on my laptop and now same on my PC.
Again Belive me when i say i have watched more videos on how to fix this sh*t than i have every spent time watching tutorials on how to fix something.
I have installed graphics drivers
Direct x
Microsoft visual C++ from 2008 to 2022 both 64 and 32bit
MS windows runtime 6.0 and 7.0
MS VS tools for applications 2012 ro 2029
Intel graphics drivers
At past i even download some dll files pack i got and dunp them into my root OS ( which is dumb)
But the error dosent seem to go and i dont know on what hell which other drivers am i to install to get this old game to run, i run evey other game FINE except GTA V.
The only thing i noticed is ( i have win 10) when i install windows 11 like i do an update not clean install then the game Works, its like the windows 11 has something in it that i don't have correctly and i dont know what that is. Again THE GAME ONLY WORKS WHEN I HAVE WINDOWS 10 AND I UPGRADED OR UPDATED TO WIN 11 WITH OUT DOING A CLEAN INSTALL, IF I DO A CLEAN INSTALL OF WIN 11 THE GAME DOSENT WORK....
I want to know the problem because i dont want to install a new window just to play GTA 5 all the time, i want to know the issue so that i can fix it. I have been trying to figure it out for almost 2 years but nothing.
Before you say its my GTA 5 that is bad or i should install it from Rockstar or epic or steam well i dont have the game so yeah i only got the installer plus why does it work when i update to windows 11 that means the problem is not the game but the windows that is missing something.
I have tired running on the game on all sorth of things that my little brain can think off but no the game JUST WONT WORK for god sake.
To anyone coming try install .net
Install vr 3.5 first and see if it dosent work proceed to install other versions
https://dotnet.microsoft.com/en-us/download/dotnet-framework
If i get flagged for this its my fault.
