Seeking Advice: Upgrading to 1440p - Will My Specs Handle High/Ultra Settings?
Solved by podkall,
How's your current smoothness/fps?
It's not the best build for 1440p but to say it's the worst is also a lie.
Not sure if High/Ultra settings will be realistic, depends on the game really.
You gotta understand that 1440p is nearly double the pixel amount 1080p screen has, so the hardware will receive between 120%-180% demand from the game, again, depending on game and settings..
