Does daisy-chaining help here, or is that just for the aRGB?
Solved by WoodenMarker,
12 hours ago, hanouzz said:Alright! I do know that my case fans daisy chain tho. Does daisy-chaining just apply to the aRGB connectors, or also to the 3/4-pin fan connectors? Because including the CPU fan, I have 6 fans.
You could just ignore the extra Delta fan so there shouldn't be need to daisy chain to power fans but your can do so if it makes cable management easier. Probably worth doing for the argb.
