Help
So I changed my CPU cooler for a arctic liquid cooler 3 argb 240mm and now my PC won't boot
The lights turn on but nothing shows on screen
display cable in GPU and not mobo port?
AIO connected to either chassis or pump fan?
CPU reseat done?
Any debug lights?
Message me on discord (bread8669) for more help
Current parts list
CPU: R5 5600 CPU Cooler: Stock
Mobo: Asrock B550M-ITX/ac
RAM: Vengeance LPX 2x8GB 3200mhz Cl16
SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB
GPU: MSI RTX 3060 Gaming X
Fans: 1x Noctua NF-P12 Redux, 1x Arctic P12, 1x Corsair LL120
PSU: NZXT SP-650M SFX-L PSU from H1
Monitor: Samsung WQHD 34 inch and 43 inch TV
Mouse: Logitech G203
Keyboard: Rii membrane keyboard
Damn this space can fit a 4090 (just kidding)
7 minutes ago, Legendario1973 said:
All tried no debug lights
Check your power connectors on the GPU. Check they're all seated correctly
System specs?
Current parts list
Msi rtx 3060 12gb 13400f mars gaming mpii 850w psu 32gb Corsair vengeance ram crucial P3 plus and done
Try reseating your GPU (taking it in and out of the pcie slot)
Remember to push the pin on the side down
Oh and MBO gigabyte b760m gaming x ddr4
Are you getting into bios at all?
Current parts list
2 minutes ago, Legendario1973 said:
I'm not getting into bios
Check your display connection on the monitor side. If your monitor is on and the display connection on the GPU side too
Current parts list
I think there are bent pins in the socket what do I do
Have you checked? your motherboards probably dead
Have you still got a warranty on the board? if so try and process it
Current parts list
ye you definitely have. Do you know if they were there before?
Current parts list
Nope
so the motherboard isn't still on warranty?
Current parts list
The MBO is still in warranty but does it cover this? How do I put the stock cooler back on?
6 minutes ago, Legendario1973 said:
Can't I unbend them?
that's both risky and quite hard to do correctly
yes it should
there should be 4 pins on the corners with either screw holes or thumb screws
My parents are so mad at me
Happens to us all. if it's still in warranty it should be fine. Contact Gigabyte support if your pc doesn't boot with the stock cooler
Current parts list
yes it should
If it is still under warranty i wouldn't attempt to bend the pins back. While it can be done it is very fragile and you could end up worse than you started.
Technology is like a good friend that does its best to piss you off at every turn. yet we love them anyway.
Posted (edited)
I wouldn't cover a motherboard with bent pins, I bet manufacturers won't either.
A quick search seems to support that.
And I agree, unbending pins is really difficult if not impossible. But I'd try it if the board wasn't covered.
Edited by leclod
I'm willing to swim against the current.
I'm afraid so, they're considered user damage. The best OP can hope for is usually a subsidised repair.
My parents said and there is no way they will let me replace it ever warranty is my only choice
Check if it’s covered by the warranty
Current parts list
