Help
Message me on discord (bread8669) for more help
Current parts list
CPU: R5 5600 CPU Cooler: Stock
Mobo: Asrock B550M-ITX/ac
RAM: Vengeance LPX 2x8GB 3200mhz Cl16
SSD: P5 Plus 500GB Secondary SSD: Kingston A400 960GB
GPU: MSI RTX 3060 Gaming X
Fans: 1x Noctua NF-P12 Redux, 1x Arctic P12, 1x Corsair LL120
PSU: NZXT SP-650M SFX-L PSU from H1
Monitor: Samsung WQHD 34 inch and 43 inch TV
Mouse: Logitech G203
Keyboard: Rii membrane keyboard
Damn this space can fit a 4090 (just kidding)
I'll try to use the m100r if not this maybe a good option
5 minutes ago, Legendario1973 said:
I found this on PcComponentes refurbished page
https://www.pccomponentes.com/lian-li-pc-o11-dynamic-cristal-templado-usb-31-blanca?refurbished
Although I will try to still be able to use the m100r via saw
O11 isn’t bad but it comes with no fans. If the m100r is about 30 euros cheaper get the m100r
Current parts list
No I meant my current m100r that I can't remove the MBO from I'll just saw off the mbos screws
I'd put a back fan I have from the size the case uses for back fans no under fans 3 side fans my 240 rad on top with another fan if said fan doesn't fit It goes down
I’d say try to use the m100r
sounds good
Current parts list
Just now, Legendario1973 said:
This is like the o11d but from a spanish brand (basically it's cheaper) i would honest kill to see Linus check some mars gaming products out specially psus cause i dont trust them
https://www.pccomponentes.com/mars-gaming-mcv4-torre-xxl-e-atx-cristal-templado-lateral-y-frontal-sin-marco-negro
the case looks fine, which psu were you looking at?
Current parts list
My current one which I wanna change cause of trust issues mpII 850w
what's your budget for psu do you think?
Current parts list
What I convince my parents to let me
if it's working fine now I don't see any reason to change it
but this is a good option
MSI MAG A650BN 650W 80 Plus Bronze | PcComponentes.com
Current parts list
I got the Mac and I convinced my parents to let me use my own money in semana santa to fix my pc
So. Today I can get the MBO. But I can't decide which what do you think?
1.https://www.pccomponentes.com/asus-tuf-gaming-b760m-plus-wifi-d4?campaigntype=eshopping&campaignchannel=shopping&gad_source=1&gclid=Cj0KCQjw2PSvBhDjARIsAKc2cgNlRGHQ8qdOE7oM1LWiBcYdTiQnbj_TbdnXe7gr8NoP77L7htVvedsaAocQEALw_wcB
Or 2.https://www.pccomponentes.com/msi-pro-b760m-a-wifi-ddr4
Same price? Get the msi. If the ASUS is cheaper then get that
Current parts list
Btw how should I get the screws that Dont screw out? Since the mbos dead just rip it off with no worries about the MBO?
if you're sure the mobo is dead then yes
Current parts list
Today I get the new MBO I managed to get the old one out without breaking it or the case. I'm waiting for PcComponentes now. I bought the Asus tuf model
Only 1 standoff didn't make it
Should be fine without it
nice. Tell me how it goes
Current parts list
