I have a 400 watt psu, but no pcie 6pin cables
Power supplies produce 3 voltages : 3.3v , 5v and 12v and on some power supplies a part of the total power is reserved for 3.3v and 5.0v so even though the power supply is advertised as 400 watts, it may not be able to supply 400 watts on 12v, which is what's used in modern computers to power the processor and the video cards.
On amazon there's a picture showing the table with the voltages and power available on each voltage, and that table says 12v 32A, which means 12 x 32 = 384 watts available on 12v.
The thing is, that's true if that's 100% genuine and they're not exaggerating or inflating the numbers. and the internals are like in the picture on the box on Amazon, I would say at least 300 watts on 12v would be realistic on that power supply.
What can you do now.. well, not much, maybe try a 2 x molex (old hard drive connector) to a pci-e 6+2 / 8 pin adapter. They should be better than the 2xsata - pci-e 8 pin adapters
