How many friggin 5v rgb do I need??
Solved by OddOod,
51 minutes ago, OnionRings said:take a 12v and divide it into two 5s
That's not a thing. That's not how that works
51 minutes ago, OnionRings said:really do need 3
I think not. The fans are daisy chainable which says to me that you should be able to get all the things to run off one header. You might need to get an extender to get from the fans to the pump
Featured Topics
1
Joseph_Stalin ·
Posted in General Discussion3 -
Evan37 ·
Posted in New Builds and Planning5 -
IlanMS ·
Posted in Peripherals9 -
Frossty ·
Posted in Graphics Cards9 -
StephenB95 ·
Posted in Displays4 -
5
