7200rpm SSHD with 8gb flash vs 5400rpm SSHD with 16gb flash
the rpm is not the only thing... one drive could have a newer generation of platters with higher data density so you'd get same amount of data in one second, or even more.
seagate datasheet here : https://www.seagate.com/docs/pdf/datasheet/disc/ds_momentus_xt.pdf
The seagate has 2 platters, 4 heads, and it's designed with 4096 byte sectors, not 512 bytes as it's the default.
can't find specs for the wd black but on some random page i found it's native 512 byte sectors (so more compatible) and it has 2 platters / 3 heads ... so it squeezes 250 GB per platter surface compared to maybe 180 GB per platter surface on Seagate, this means at each rotation more data is read on the WD drive.
It's 16GB MLC while the seagate uses SLC but doesn't really matter... in theory the drive is supposed to figure out what is read most often from platters and cache it in those 8/16 GB ... so when you first install the drives you won't get any benefit.. it would take some time for the drive to figure those out and start caching (several windows reboots and it should start caching OS files and drivers that load at startup)
