Why does Instagram not allow me to use photos from my camera?
Solved by Caveman0407,
4 minutes ago, Eigenvektor said:How exactly are they preventing you from using them, do you get some error message or similar?
Basically, When I try to post a picture from my camera it simply doesn't show up as an option to select. I can go to my gallery app and try posting an image through that but only stories and reels work while posts do not (I'm trying to post something). What I'm doing right now is just transfering the images I want to post and moving them off the sd card (where they're originally stored)
Update: that worked. But it would still be nice to be able to acces the SD card again
