will my motherboard fit
acl_13
I'm making a PC and I was wondering if you can fit the Gigabyte G1.SNIPER 5 motherboard in the raidmax vampire case (I know the motherboard is an eATX and the case is atx) i Just need to know if it will work.
no
also stay away from that case.
It would fit.
Eatx and ssi eeb share mounting holes.
redacted, would still advise against buying the case.
Error: 410
no
It would fit.
As long as it doesn't interfere with the front bays and the the psu i can make it
work
It would fit.
Sure about that? Raidmax's website lists miniATX microATX, ATX, SSICEB, SSIEEB, Flex ATX.
Also I don't want to be rude, but for $100+ you can get a much better case for your money.
but for $150- not that many plus I like the look of it
Yes. Like I said, SSIEEB and eATX share some mounting holes.
