Using USB C monitor without a GPU
1 minute ago, RageTester said:And then mounting mini PC to the back of monitor might be good for hiding even more cables. The only worry is quality thermal solution. Can't really install bigger fan in those tiny things.
I just don't trust SSDs fully after one died on me. And day before drive reported 83% remaining life...
Once its below 90 toss
And going back to hard drives is just a bad bad bad bad idea especially for databases slow as mollases.
They also flat out are NOT more reliable.
Also having a basic backup strat is a must and will avoid data loss pain for a small price.
As for cooling if its a efficient cpu its fine
Anyways mounting behind the monitor is often not possible due to vesa mount obstructions and also not hiding more cables usually since now a power cable has to go to the screen and you managed to hide the display. So basically a trade.
Id also just advice a normal desktop or a smaller one just for ease of maintenance and such.
