Case with 140mm 3x front, 3x bottom, 3x top, 1x rear?
bottom mount fans are less common and most cost a bit more. Fractal Design case are good quality form what i heard so its worth the price.
having 3x 140mm fans on the bottom and top are also a bit more rare. having 2x fans would make the case shorter.
Fractal Design also have case that are different sizes too.
new egg and i think pc part picker i think you can shertch case for bottem fans thow on pc park picker it will aslo list case the are dc so can be a bit confusing and some time the info is not right...
Antec Performance 1 FT can do 3x 120mm on the bottem 3x 140mm on top but think it cost a bit...
Phanteks Enthoo Pro 2 3x 120mm on the bottem 3x 140mm on top not a small case thow
Lian Li Lancool 216 2x bottem fans
Lian Li LANCOOL II MESH 2x bottem fans
Lian Li Lancool III 3x bottem fans cost thow
Lian Li O11 Dynamic XL 3x 120mm or 2x 140mm
lian li evo 2x bottem and top the mount is janky thow...
Segotep T1 kinad 3 front 3 back?
Antec Performance Series P120 Crystal can do 3x140mm on the bottem but no top and no front just side.
ASUS TUF Gaming GT502 can so 3 and 3 im gussing 120mm fans
Thermaltake CTE C750 Air can do the most but its a side mb and the pannals dont attach... (i have this case) big case thow...
Thermaltake CTE T500 bit smaller
Thermaltake CTE T500 TG
LIAN LI PC-O11
