Cables on Thermaltake PF3 PSU enough for 3090?
46 minutes ago, CephDigital said:Hi there!
So I have a Thermalright PF3 750W PSU and an MSI RTX 3090 Trio (on a waterblock) and an AMD Ryzen 7 7800X3D.
I know the Nvidia website recommends a 750W PSU but the cables themselves is what concerns me, as it requires 3 x 8 pin PCIE connectors and I've heard of the 3090 pulling more than 300W of power. The PSU has 2 connectors on itself for PCIE cables that each split into 2 PCIE connectors. That's still only 300W of power. Is this going to be fine or should I return my PSU? There's also a 12VHPWR connector on the PSU but I can't find an adapter to convert it to PCIE ports.
I'm in the UK if that helps.
Each 8-pin connector by spec supports 150W, but I would believe that they have some extra leeway up to ~200W or so. Your GPU at stock is rated for 370W, if you count the 75W from the PCIe slot you have 150+150+75= 375W.
FWIW, my 3090s are 2x8-pin only and can go up to 370W, and I have run them at full tilt some times with no issues and only 2 cables each.
