I have been scouring the internet for about an hour and I've only found 3 options. I'm looking for a laptop with a 4080 and a Ryzen 9 CPU and from my extreme googling there aren't many options. I'm looking at the ASUS ROG Strix Scar 17. or the ASUS ROG Zephyrus DUO 16 (but the Duo 16 is a bit over my budget) most important part is the cooling and performance. how the keyboard feels or how the monitor looks is almost completely irrelevant. since I'm connecting it to a setup and the laptop will stay stationary most of its life.
But I still need a laptop since i travel overseas twice a year, I do physical 3d classes and online classes. "Most of it's life" is more like 250 days out of 365
I'm going for a Ryzen CPU since I'll be doing a lot of 3d rendering and a lot of editing. 4080 is the highest I can go. and I need good opticx performance and raytracing. budget is around 3k. but even that is pushing it.
Edited by Kevin.Sahlstrom
Added more info
The only other one I could find would be the Lenovo Legion Pro 7 16ARX8H. Which is supposedly pretty good as well, but will also nearly reach your price point.
Have you considered getting a normal laptop and have a dedicated desktop at home? If you have a good internet connection where you have to work on editing and at home, you could always use something like parsec to connect to it.
If you don't plan on moving it: get a desktop, as that will get far more performance at a lower price.
If you do plan on moving it, but only need to do simple browsing on word processing on the move: get a desktop and a cheap laptop.
I might be experienced, but I'm human and I do make mistakes. Expand for common PC building advice, a short bio and a list of my components and other tech. I edit my messages after sending them alot, please refresh before posting your reply. Please try to be clear and specific, you'll get a better answer. Please remember to mark solutions once you have the information you need.
Common build advice: 1) Buy the cheapest (well reviewed) motherboard that has the features you need. Paying more typically only gets you features you won’t use. 2) only get as much RAM as you need, getting more won’t (typically) make your PC faster. 3) While I recommend getting an NVMe drive, you don’t need to splurge for an expensive drive with DRam cache, DRamless drives are fine for gamers. 4) paying for looks is fine, just don’t break the bank. 5) Tower coolers are usually good enough, unless you go top tier Intel or plan on OCing. 6) OCing is a dead meme, you probably shouldn’t bother. 7) "Bottlenecks" rarely matter and "Future-proofing" is a myth. 8) AIOs don't noticably improve performance past 240mm.
useful websiteshttps://www.productchart.com - helps compare monitors, https://uk.pcpartpicker.com - makes designing a PC easier.
He/Him
I'm a PhD student working in the fields of reinforcement learning and traffic control. PCs are one of my hobbies and I've built many PCs and performed upgrades on a few laptops (for myself, friends and family). My personal computers include 3 windows (10/11) machines and a TrueNAS server (and I'm looking to move to dual booting Linux Mint on my main machine in future). While I believe I have an decent amount of experience in spec’ing, building and troubleshooting computers, keep in mind I'm not an expert or a professional and I make mistakes.
Favourite Games of all time: World of Tanks, Runescape, Subnautica, Metroid (Fusion and Dread), Spyro: Year of the Dragon (Original and Reignited Trilogy), Crash Bash, Mario Kart Wii
Main PC: https://uk.pcpartpicker.com/user/will0hlep/saved/NByp3C
Secondary PC: https://uk.pcpartpicker.com/user/will0hlep/saved/cc9K7P
TrueNAS Server: https://uk.pcpartpicker.com/user/will0hlep/saved/m37w3C
Laptop: 13.4" ASUS GZ301ZE ROG Flow Z13, WUXGA 120Hz, i9 12900H, 16GB DDR5, 1TB NVMe SSD, 4GB RTX 3050 Ti, TB4, Win11 Home, Used with: 2*ThinkPad Universal Thunderbolt 4 Dock, Logitech G603, Logitech G502 Hero, Logitech K120, Logitech G915 TKL, Xbox Elite Wireless Controller Series 2, Logitech G PRO X Gaming-Headset (with Blue Icepop in Black), {specs to be updated: two monitors}
Other: LTT Screwdriver, LTT Stubby Screwdriver, IFIXIT Pro Tech Toolkit, Playstation 1 SCPH-102, Playstation 2 SCPH-30003, Gameboy Micro Silver OXY-001, Nintendo Wii U WUP-001(03), Playstation 4 CUH-1116A, Nintendo Switch OLED HEG-001, Yamaha RX-A4A Black AV Receiver, Monitor Audio Radius (4*90s, 1*200s, 2*270s, 1*380s), TP-Link TL-SG105-M2, Netgear GS308, IPhone 14 Pro Max 128GB Space Black, Secretlab TITAN Evo (Black SoftWeave Plus Fabric), 2*CyberPower BR1200ELCD-UK BRICs Series, Samsung 40" ES6800 Series 6 SMART 3D FHD LED TV, UGREEN USB 3.2 Gen 2 10Gbps M.2 NVMe SSD Enclosure, SABRENT 3.5" SATA drive docking station
Then why not a desktop? Way cheaper for the same perfromance.
If you very very very infrequently need to be on the go. Plenty cheap laptops out there that pack a SERIOUS punch.
I travel overseas about twice a year. And i'm doing online school. And I have plenty of times where I need to unplug and leave. I'll be able to get a desktop in 3-4 years when I move tho. This is just a Insurance until then
I plan on moving it. I travel about twice a year and need something to plug out when I go to school. (I'm a 3d artist, hence the high end spec requirements)
Check edit😁 problem with that is when i'm on the move i still need a laptop that has pc like performance since I'm still working 99% of those times. And getting both would be way to expensive. I'll rather get something that can do both without issue. I have tried using a friends pc over cloud. But the latency is horendus
