I’m looking to replace/upgrade a TV in my home and been looking at 65” LED TVs. Pretty much any online discussion about TVs seems to be comparing technologies to each other: LED vs MicroLED vs OLED etc. I know LED backlit is not the “best” picture quality and I’m okay with that. That all being said, is any one manufacturer better than another or does it really just come down to brand preference? In the past I bought Vizio but LG, Sony, and Samsung all have TVs in the same price range.
https://linustechtips.com/topic/1536844-choosing-an-led-tv/
I personally always look at Rtings.com
They have very detailed TV reviews so you can look for what's most important to you. For example: Gaming performance, black levels, viewing angles etc.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1536844-choosing-an-led-tv/#findComment-16175614
It comes down to the Panel installed in the Display and the electronics supporting it.
As @FloRolf says Rtings does a fantastic job testing Displays. Here's their Fall 2023 Roundup of 65" Displays
Also important to know is budget? what kind of Content (4k? HDR?) do you want to consume, is it a bright or dark room? and do you want to game on it?
I bought a 55" LG C2 OLED recently on Clearance and Wow!, what a difference compared to the 55" Samsung 1080p panel it replaced. I had to replace the Apple TV it was connected to with a Apple TV 4k (wife appeal factor) and new Ultra 4k HDMI cables to get the eARC working properly between the panel and Sound Bar.
FaH BOINC HfM
Bifrost - 6 GPU Folding Rig  Linux Folding HOWTO Folding Remote Access Folding GPU Profiling ToU Scheduling UPS
Systems:
desktop: Lian-Li O11 Air Mini; Asus ProArt x670e WiFi; Ryzen 9 7950x; EVGA 240 CLC; 2 x 48GB DDR5-6000; 2 x Samsung 980 Pro 500GB PCIe3 NVMe; 2 x 8TB NAS; AMD FirePro W4100; Corsair SFF750
nas1: Fractal Node 804; SuperMicro X10sl7-f; Xeon e3-1231v3; 4 x 8GB DDR3-1666 ECC; 2 x 250GB Samsung EVO Pro SSD; 7 x 4TB Seagate NAS; Corsair HX650i
nas2: Synology DS-123j; 2 x 6TB WD Red Plus NAS
nas3: Synology DS-224+; 2 x 12TB Seagate NAS
dcn01: Fractal Meshify S2; Gigabyte Aorus ax570 Master; Ryzen 9 5900x; Noctua NH-D15; 4 x 16GB DDR4-3200; 512GB NVMe; 2 x Zotac AMP 4070ti; Corsair RM750Mx
dcn02: Fractal Meshify S2; Gigabyte ax570 Pro WiFi; Ryzen 9 3950x; Noctua NH-D15; 2 x 16GB DDR4-3200; 128GB NVMe; 2 x Zotac AMP 4070ti; Corsair RM750x
dcn03: Fractal Pop Silent XL; Gigabyte Aorus z370 Gaming 5; i9-9900k; BeQuiet! PureRock 2 Black; 2 x 8GB DDR4-2400; 128GB SATA m.2; MSI 4070 Ti Super Gaming X; MSI 4070 Ti Super Ventus 2; Corsair RM750e
dcn04: Fractal Meshify C; Gigabyte Aorus ax570 Master; Ryzen 9 5950x; BeQuiet! PureRock 2; 2 x 16GB DDR4-3200; 250GB NVMe; Asus RTX 4070 Dual OC; MSI 4070 Ti Super Ventus 2; Corsair TX650m
dcn05: Fractal Define S; Gigabyte Aorus b450m; Ryzen 7 2700; AMD Wraith; 2 x 8GB DDR 4-3200; 128GB SATA NVMe; Gigabyte Gaming RTX 4080 Super; Corsair TX750m
dcn06: Fractal Focus G Mini; Gigabyte Aorus b450m; Ryzen 7 2700; AMD Wraith; 2 x 8GB DDR 4-3200; 128GB SSD; Gigabyte Gaming RTX 4080 Super; Corsair CX650m
https://linustechtips.com/topic/1536844-choosing-an-led-tv/#findComment-16175664
If you're on a budget,
TCL and Vizio have great options. Hisense has an excellent option if you're willing to play the lottery - check RTINGS for the model
Mid-range you can look at Vizio's high end options, and Samsung's QLED (this is still LED backlit, but Quantum Dots give better color)
At upper mid-range you move into LG's C-series OLED televisions and above that is their brighter G-series line-up.
If you've got a fat budget, Sony's OLED is top-tier.
| Remember to mark Solutions! | Quote Posts if you want a Reply! |
| Tell us everything! Budget? Currency? Country? Retailers? | Help us help You! |
https://linustechtips.com/topic/1536844-choosing-an-led-tv/#findComment-16175924
DigitalTrends' Youtube channel is a great great resource for TV reviews and explainers too.
I like smart home and home theater tech.
My 5.1 setup consists of: Sony x90cj 75" TV, Yamaha RX-V4A Receiver, Apple TV 4k gen 2, SVS SB-1000 Pro Sub, KEF Q350 L/R, KEF Q250c Center, KEF Q150 rears.
My smart home is built around Home Assistant.
https://linustechtips.com/topic/1536844-choosing-an-led-tv/#findComment-16178217
