pc audio output stopped working with earc
Solved by circeseye,
27 minutes ago, bitezadusto3731 said:Is there a way to get HDR to work doing that? When I tried that earlier I had it set to 8k signal enhanced and it would only run SDR 8 bit. I have windows 11 if that makes any difference. It wouldn’t give me any option for HDR
hdr works fine..im running win 11, 4k 120 444 10bit hdr on the x3600h...so i know the x3700h can
oh and do the res and stuff in windows not nvidea control panel
