help Used PC Appraisal Help
Solved by SorryBella,
5 hours ago, DryValley said:Other details:
Here is the list of parts he sent me:
- Motherboard: Asus Rog Maximus XI Code
- CPU: Intel(R) Core (TM) i7-9700K CPU @ 3.60GHz 8/8
- RAM: 32 GB G.Skill 8GB × 4
- GPU: NVIDIA GeForce RTX 3070 (8 GB)
- CPU Cooler: Corsair H100i Pro
- Power supply: Corsair TX850M
- HDD: WDC WD20EZRZ-00Z5HBO
- SSD: Samsung 860 EVO 1TB
- Monitor: Acer KG271 B 27.2 Inch
- Keyboard: Ducky One 2 Mini RGB
- Mouse: Logitech 9402
No more than 600-700 GBP for PC alone. You're going to need to replace the CPU platform on your own, and you're missing an Nvme drive which would be a really great QoL in terms of Windows usage.
And personally I don't touch used peripherals unless if I'm desperate. Out of the 3 things the Ducky is the only one id bat an eye. A lot of ergo gaming mice in the sea that's not weighed like an anchor and the monitor is outdated.
