4770k or wait for 4790k with my build?
Solved by Wano97,
Thanks, how come there's no difference though? I guess what I'm saying is I don't understand what the benefits would be to upgrading from a 4770k to a 4790k would be. Do you know?
Because there's nearly no difference from a 4770k to a 4790k if I remember correctly, but a 4930k won't improve that much either. It's mainly your GPU that's doing the job, aslong as your CPU doesn't bottleneck, which a 4770k will certainly NOT, you're fine
