Best sub 400$ monitor
Mixzzz
So I'm trying to choose a monitor with 400$ budget. My requirements are 1440p, 27-32in, at least 120hz monitor. Main uses are gaming and work(Mostly working with spreadsheets and translating documents). So far googling the best options, it seems that I've landed on GigaByte M27Q however people say that this monitor won't have the best text clarity which kinda makes it problem. Is it really that bad? What other decent options do I have?
CPU: AMD R7 5800x | GPU: XFX 5500XT 4GB | RAM: 2x8GB Kingston Fury Renegade 3600MHz CL16 | Cooling: Deepcool Gammaxx L360 | MB: Aorus B550 Elite V2 | Storage: Samsung 850 Evo 250gb & WD20EAZX | Case: Antec DF700
Lenovo ThinkPad Yoga 460: Intel 6200U | 8GB | 256GB SSD | Active pen
The original M27Q has BGR subpixels, that's why it didn't have best text clarity. The updated variant called M27Q-P fixed subpixels to RGB (and other minor upgrades) so it should have ideal text clarity like any other 1440p 27 inch monitors.
PC spec: CPU: RYZEN 9 5950X | GPU: SAPPHIRE NITRO+ SE AMD RADEON 6900XT (Undervolt to 1045mV) | MB: MSI MAG TOMAHAWK x570 RAM: G.SKILL TRIDENT Z NEO 32GB (2x16GB) DDR4-3600 (OC to 3800 14-15-15-25) COOLING: NOCTUA NH-D15, BE QUIET! SILENT WINGS 120 & 140mm| CASE: IN-WIN 707 | 5.25" BAY: LG WH16NS60 INTERNAL BLU-RAY OPTICAL DRIVE | PSU: SEASONIC PRIME PLATINUM 1000WUPS: POWERSHIELD COMMANDER TOWER 1100VA
PERIPHERALS: KEYBOARD: CORSAIR K95 PLATINUM XT BROWN SWITCH | MOUSE: CORSAIR SABRE PRO WIRELESS | CONTROLLER: PDP AFTERGLOW WIRED CONTROLLER, DUALSENSE
DISPLAYS: LG 34GN8502x DELL S2721DGF | LG C1 48"
HT & audio stuff:  AVR: MARANTZ SR7013 | STEREO AMPLIFIER: YAMAHA AS-501 | SPEAKERS: DALI OBERON 7 & DALI ZENSOR 1 & 2x SVS-SB2000 | HEADPHONE DAC+AMP: TOPPING L30+E30 | HEADPHONE: SENNHEISER HD6XX, BOSE QUIETCOMFORT 35 II | MICROPHONE: AUDIO-TECHNICA AT9934USB | BLU-RAY PLAYER: PANASONIC UB820
best sub 400 would probably still be the mag274qrf-qd, though if you wish to save a bit, can't go wrong with the m27q-p.
though at current pricing the m27t20 basically gets you the best 27inch panel for 460usd.
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
At 27" i'd recommend the LG 27GP850-B.
At 32" i'd recommend the LG 32GP83B-B.
Both are great monitors so pick your size preference.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
Sadly M27Q-P is not available where I live, says out of stock everywhere.
The MSI one is more like 500$ in EU and can't find m27t20
Hmm, to me it seems that 27GP850-B seems to be almost worse in everything except for text clarity when compared to M27Q when comparing them in rtings. Like less contrast, less bright etc. Or in reality that wouldn't be noticeable?
It's a bit worse and hardly noticeable. Comparing to VA panel it would definitely be noticeable as they usually have around 1:2500-1:4000 contrast ratio. As for brightness it wouldn't matter, unless you really need to raise up to 100% for a reason.
Generally 27GP850 have better response time compared to M27Q so yes it's worth considering.
the LG has better response time and slightly better color coverage, but the contrast is pretty bad, is overall the better monitor would not recommend in a dark room, the m27Q-P is decent at everything.
https://www.rtings.com/monitor/reviews/lg/27gp850-b-27gp83b-b
Ok...Basically the only 2 decent options are M27Q and 27GP850? Cause everything else I've been looking at seems to be worse than either of these 2.
Yeah, This would be a great option however I can't find it in stock anywhere in EU.
There's a lot of decent 1440p 144hz+ IPS monitors out there such as LG 27GL850/27GL83, 27GN800, 27GP850/27GP83, Gigabyte M27Q-P, Asus VG27AQ, Dell S2721DGF, MSI MAG274QRF-QD, Acer Nitro XV272U and several more I missed out.
What are you looking for exactly? Highest refresh rate? Cheapest? Best ergonomics?
For example me and my siblings went with S2721DGF because it was cheapest in my country and I can rotate to portrait mode either way without needing to buy VESA stand.
Well, I was going for 27, 1440p 120hz+ within 400$ and most of these were either not available or had some sort of big con. Anyway, I just checked and somehow one of my local stores got 1 M27Q-P apparently in stock so I ordered it and I'll see if they can actually deliver it.
Also, according to rtings M27Q isn't that bad at native scaling regarding text clarity and not bad at all with cleartype so that would fit me but what's even better news is that apparently M27Q rev 2.0 has RGB pixel layout and should perform just as well so I'll probably just order the M27Q if the P variant isn't available.
