After delidding 7600x temps idle at 70c-80c and under medium load immediately spike to the 96c cap
2 hours ago, berrigan said:The title just about sums it up. After getting warm temps with the 7600x I decided to delid my CPU after seeing Der8auers video and followed it best i could. Thankfully my CPU isn't dead yet. However, the temperatures are really high and reach the maximum temperature very easily, more easily than before idling between 70c-80c. I've tried different amounts of liquid metal from a little bit to a decent amount, also applying different amounts of pressure to ensure good contact. Since I had a similar issue before delidding my CPU I thought it might be my X53 Kraken finally dying on my after the last few years after it had been making some noises which I thought might be the pump failing, so I decided to get the newer model. After installing the newer Kraken 240mm AIO the same thing happens. It idles high and maxes out under medium load. I am absolutely stuck and would greatly appreciate any insight into what might be going on. Thanks in advance.
EDIT: All it was was a contact issue. Screwing the screws in tighter although being careful not to crack the die has worked wonders. This is not quite the improvement i saw from other YouTubers however this is due to the flimsy mounting bracket that comes with Kraken coolers creating a less ideal contact. That being said I am now seeing better temps than before delidding. At 100% usage it never hits 95c, I have left it for a while and it is struggling to hit the 95c temp cap at stock settings no overclock or undervolt. Using a custom water block with a more sturdy contact will likely increase the improvements seen. This ordeal ended up being worth the hassle having learned a few things if nothing else.
Solution is in original post as "EDIT"
