Why am i loosing my 4th monitor to DSC?
Go to solution Solved by Teletha,
oh it seems it uses 2 ports to aggregate the bandwidth when DSC is turned on. Kinda weird if it already compresses it down to 21Gbps
i have 2 1080p 60hz monitors, and a LG 4K 120hz and the G9 neo at 5120x1440 120hz
When i enable 240Hz on the neo i lose my 4th 1080p monitor, to DSC.
But isn't it still the same bandwidth that is going thru the cable, why does it need to remove the max outputs to only 3 monitors?
AMD Ryzen 9950X3D [x2 360 Rad EKWB] | Asus Extreme x670E | RTX TUF 4090 OC@3GHz [EKWB Block] | Corsair HX1500i | G.Skill Neo CL30 6000MHz (2x32GB) | MP700 2TB Gen5 + 980/950 Pro 1TB M.2 | x6 85PRO 512GB | NAS@10Gbit/s 4x 24TB Seagate Exo Raid 10 (2x 1TB raid 1 NVME Cache) - 4x 1TB NVMe Raid 0 + Backblaze | Lian-Li o11D XL | Main Screen: Samsung OLED G9 | AUX: LG IPS7 27" (x2) LG CX 55" G-Sync | 10Gbit/s ISP connection | Copyright©1996-2025 Teletha All rights reserved. ®
https://linustechtips.com/topic/1509589-why-am-i-loosing-my-4th-monitor-to-dsc/
Some gpus can only give a certain amount of bandwidth on all ports at the same time. This is normal since most gpus can't run ALL the ports at the highest bandwidth. It's annoying but its therew
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
but with 120hz the bandwidth is still maxing out the cable at 31.85Gbps so if anything the DSC should make it even lower
DSC is 3:1 compression so the bandwidth of the display at 240 is 63.7 Gbps and compress it with 3:1 will make it 21.23 Gbps
unless dsc is on even at 120hz? then it would be only running 10.61Gbps at 120hz
its weird. Do you have an igpu you can use?
Total: £1040.95
ye but the pc gets random black screen with that on sadly
I think you might have to live with the lower refresh rate then or lower the refresh rate/res on the LG 4k 120hz monitor
Total: £1040.95
i tried lowering everything apart from the 240hz but it wont enable the extra port its hardlocked if dsc is active it seems.
Try turning it off then
Total: £1040.95
It's a pixel rate limitation (i.e. before the compression is applied), the final transmission bit rate is not the issue.
Do you think this will have the same issue on DP 2.1 on the 5000 series nvidia gpus too?  Since i will have to upgrade in that case so i can get DP 2.1 without needing to use DSC so i can ultimately have 4 monitors.
since the bandwidth is 63.7Gbps without DSC it has extra 17Gbps headroom but not sure if that applies to the pixel rate too
You are facing the similar issue as mine, I can only said GPU is the limitation as of now.
I lost 3rd monitor when I make my Neo G8 and Neo G9 both running at 240hz.
Is it RTX 3080 limitation or Samsung Odyssey monitor issue. Hmm... - Displays - Linus Tech Tips
PC: AMD Ryzen 9 5900X, Gigabyte GeForce RTX 4090 OC 24G, X570 AORUS Elite WIFI Motherboard, HyperX FURY 32GB DDR4-3200 RGB RAM, Creative Sound Blaster AE-9 Sound Card, Samsung 970 Evo Plus M.2 SATA 500GB, ADATA XPG SX8200 Pro M.2 SATA 2TB, Asus HyperX Fury RGB SSD 960GB, Seagate Barracuda 7200RPM 3.5 HDD 2TB, Cooler Master MASTERLIQUID ML240R ARGB, Cooler Master MASTERFAN MF120R ARGB, Cooler Master ELV8 Graphics Card Holder ARGB, Asus ROG Strix 1000G PSU, Lian Li LANCOOL II MESH RGB Case, Windows 11 Pro (22H2).
Laptop: Asus Vivobook "A Bathing Ape" - ASUS Vivobook S 15 OLED BAPE Edition: Intel i9-13900H, 16 GB RAM, 15.6" 2.8K 120hz OLED | Apple MacBook Pro 14" 2023: M2 Pro, 16 GB RAM, NVMe 512 GB | Asus VivoBook 15 OLED: Intel® Core™ i3-1125G4, Intel UHD, 8 GB RAM, Micron NVMe 512 GB | Illegear Z5 SKYLAKE: Intel Core i7-6700HQ, Nvidia Geforce GTX 970M, 16 GB RAM, ADATA SU800 M.2 SATA 512GB.
Monitor: Samsung Odyssey OLED G9 49" 5120x1440 240hz QD-OLED HDR, LG OLED Flex 42LX3QPSA 41.5" 3840x2160 bendable 120hz WOLED, LG UltraGear Gaming Monitor 34" 34GN850 3440x1440 144hz (160hz OC) NanoIPS HDR, LG Ultrawide Gaming Monitor 34" 34UC79G 2560x1080 144hz IPS SDR, LG 24MK600 24" 1920x1080 75hz Freesync IPS SDR, BenQ EW2440ZH 24" 1920x1080 75hz VA SDR.
Input Device: Asus ROG Azoth Wireless Mechanical KeyboardAsus ROG Chakram X Origin Wireless MouseLogitech G913 Lightspeed Wireless RGB Mechanical Gaming Keyboard, Logitech G502X Wireless Mouse, Logitech G903 Lightspeed HERO Wireless Gaming Mouse, Logitech Pro X, Logitech MX Keys, Logitech MX Master 3, XBOX Wireless Controller Covert Forces Edition, Corsair K70 RAPIDFIRE Mechanical Gaming Keyboard, Corsair Dark Core RGB Pro SE Wireless Gaming Mouse, Logitech MK850 Wireless Keyboard & Mouse Combos.
Entertainment: LG 55" C9 OLED HDR Smart UHD TV with AI ThinQ®, 65" Samsung AU7000 4K UHD Smart TV, SONOS Beam (Gen 2) Dolby Atmos Soundbar, SONOS Sub Mini, SONOS Era 100 x2, SONOS Era 300 Dolby Atmos, Logitech G560 2.1 USB & Bluetooth Speaker, Logitech Z625 2.1 THX Speaker, Edifier M1370BT 2.1 Bluetooth Speaker, LG SK9Y 5.1.2 channel Dolby Atmos, Hi-Res Audio SoundBar, SONOS ACE, Technics AZ80, Technics A800E, Sony MDR-Z1R, Bang & Olufsen Beoplay EX, Sony WF-1000XM5, Sony WH-1000XM5, Sony WH-1000XM4, Apple AirPods MAX, Apple AirPods Pro 2, Samsung Galaxy Buds2, Nvidia Shield TV Pro (2019 edition), Apple TV 4K (2017 & 2021 Edition), Chromecast with Google TV, Sony UBP-X700 UltraHD Blu-ray, Panasonic DMP-UB400 UltraHD Blu-ray.
Mobile, Tablet & Smart Watch: Google Pixel 9 Pro XL (Obsidian) Apple iPhone 15 Pro Max (Natural Titanium), Apple iPad Pro 11" 2024 M4 (Space Black), Apple Watch Series 8 Stainless Steel with Milanese Loop (Graphite).
Others Gadgets: Asus SBW-06D2X-U Blu-ray RW Drive, 70 TB Ext. HDD, j5create JVCU100 USB HD Webcam with 360° rotation, ZTE UONU F620, Maxis Fibre WiFi 6 Router, Fantech MPR800 Soft Cloth RGB Gaming Mousepad, Fantech Headset Headphone Stand AC3001S RGB Lighting Base Tower, Infiniteracer RGB Gaming Chair
ye that 4k 240hz is at 71.66 Gbps even more that the neo haha. well 2 DSC monitors turns off 2 ports so you only have those 2 that are active.
Im hoping that the new msi Oled 49" has DP 2.1 so i can replace the neo and wait for the 5000 nvidia gpu for the DP2.1 hopefully it wont need DSC for the pixel rate limit.
Yup, the only thing now is waiting for RTX 5000 series and hope it came with DP 2.1 and I believe it will since 7900 XTX already came with DP 2.1, and also need change new monitor that is DP 2.1 support as well.
ye they 100% need to have it. so many high-end monitors coming out now
