red dead redemption 2 maxing out 3070ti graphics card
49 minutes ago, tommyT1 said:Hi so I've been having troubles running rdr2 ever since I built my pc. For some reason my graphics card (gigabyte rtx 3070ti) is maxing out the 3D even when I turn all the in game graphics down to low and turn off all raytracing etc. (there is a picture of it below) I've tried many things like the obvious- making sure all drivers are updated, bios is up to date etc. And then trying the not so obvious like running the game as admin, telling my monitor to override game graphics, telling my computer in the system settings to run game at high performance etc. It has aslo blue screened on me a a couple times (I couldn't get the blue screen code because it reloaded too fast). Now as for my computer specs I have the 3070ti, AMD Ryzen 7 5700X, 32GB of corsair vengeance RGB pro DDR4 3600mhz and samsung SSD 980 1tb and seagate 2tb. Now I've benchmarked my components and they all work absolutely fine, my thermals are also very good. If anyone else has had a similar problem and knows how to fix it, that would be a great help thanks. oh I'm also running windows 11 if that has anything to do with the problem.
Cap the fps at your monitor's refresh rate and raise the settings until it doesn't hit the cap anymore. Then go back a bit on the settings and it should be fine
