Will installing Linux in a low power Laptop Increase battery life substantially?
Go to solution Solved by FSP,
17 hours ago, phatrattyy said:
All right, Ill just stick with win 11 then its not worth the time loss getting it running without issues for college.
You can quickly test this using a live bootable distro on an usb stick. For debian the live images are available here (for the testing branch, to get more recent software): https://cdimage.debian.org/images/weekly-live-builds/amd64/iso-hybrid/ Use rufus or similar to put it on a usb stick with the correct settings. If you are unsure which of the Desktop environments you want I recommend using KDE or GNOME, though some of the others might be less resource intensive.
Usually most hardware is supported, if it is not very new. I'm running debian testing kde on a lenovo Ideapad and all hardware, execept the Infrared biometric unlock camera works.
Will it make the experience that much better? I have a laptop with a low-power I3 and I just need this laptop for taking notes in college. Ideally, I would like the battery to be a bit longer. Will Linux also still be able to track my battery level and be simple to understand and use efficiently?
Some distros have terrible power management, so have great power management. I'd suggest PopOS. The makers of PopOS also manufacture laptops so they're inclined to make the battery life as good as possible. PopOS has some good power management tools built into the OS panel, and has TLP included which further improves power savings.
Daily driver: Core 2 Duo T7200 | 4GB RAM | 945GM | 1440x900 | 2TB Crucial MX500 | Void Linux | Dell Latitude D620
Gaming PC: i7 4790 | 16GB RAM | RX 560 4GB | 500GB boot SSD & 2TB 7.2K HDD & 250GB SSD | Ubuntu 22.04 LTS | Dell Optiplex 9020
Expand to help Bunny reach world domination
(\__/)
(='.'=) This is Bunny. Copy Bunny into your signature to
(")_(") help him on his way to world domination.
 -Rakshit Jain
So what laptop are we talking about here. Low power i3s have been around for a decade so you need to be more precise. Linux can be more power efficient in some ways but worse in others. The base OS is usually not the issue when it comes to battery life but the application you execute or have running in the background. Both OSes will have them and managing them is equally as painful. If you are skilled enough, you could compile all the applications to only fit your machine, that would make it more efficient but that task also would take days on a slow laptop and while you gain performance per watt efficiency you do rarely gain much battery life overall. For an older laptop running a base version of Debian would work quite well but if you feel at home with Windows and you don't have time to learn something new (other than your studies) running an older version of Windows like 7 would drain quite a bit less power than 10 and 11 do. Out of the box some Distros track battery life really well but none of them optimize background tasks to increase it that well. There are applications that will do that but then you are getting a bloated OS like Windows.
Just leavin my 2ct here:
Installed Debian on an older Lenovo Ideapad.
1h Battery Life on Windows
4h Battery Life on Debian
Debian is actually a really good idea, you can cut out the cruft by just not installing it, and only install the tools for power management you want.
I use an x220 Thinkpad and get about 7-8 hours out of it, I can't see it getting that battery life with useless nonsense running in the background.
I have it do that hibernate/sleep thing too, so it copies the running ram to disk on sleep, then if I don't wake it up within a certain time it just shuts down into "hibernate" mode - means I can just close the lid on a Friday, and on Monday morning it still has battery life.
I will try Debian. Will it be able to run chrome and log into my google accounts? Will it out of the box pick up my internal network card, display, and all other drivers? What is a good resource for Debian use? This laptop also takes an m.2 drive so ill just remove this drive and install a new drive to install debian.
This comes with an absolutely massive "it depends". If the hardware is well supported, then you probably will see some improvements in battery life. But if the laptop has some one off SKU for the motherboard, wifi chipset, or something then it might not make a difference.
What will matter much more than your choice of OS is your battery health. If the laptop is old, and replacement batteries are still for sale getting one will probably do more than almost anything else you can do.
Yeah, to be honest, I gave up the Webcam and proper BT for that. Found no fitting drivers.
But being able to use that thing for that extended amount of time is very much worth it.
Ok I gave it a go its a acer aspire five with a low power laptop 10th gen (I think) i3. All drivers successfully worked but battery life maybe increased by about 20 mins with a looping 4k video. overall not worth it and went back to win 11
What desktop were you using?  Default gnome, or KDE?  I really do still think it makes a difference.  I know it did in the kde 4.x but that is probably a poor example with how much improved KDE v5 is.
In Windows for battery power plan advanced settings, you can limit both minimum and maximum cpu percentage, which is actually changing the processor speed.
0% will set it to the slowest allowed speed, where 100% will be the fastest allowed speed.
Linux also has cpu-frequency tools or governers, which can offer similar changes.  Phoronix has a good write up of how the different modes affect performance vs battrery runtime.
"Now you get what you want But do you want more?"
- Bob Marley, Rastaman Vibration album 1976
Why do you need a 90 or 120 or 144 or 165Hz screen on a smartphone?  You're viewing 60Hz games (maybe, I hope so) and viewing 60Hz or even 30Hz content, so how does this improve your quality of life?
OLED is cool and all, but LCD is fine, I think we probably stare at these things more than is healthy anyway.
Speaking of, my favorite software for screens is
https://justgetflux.com/ so your screen isn't bright white at night, released in 2008 and still being improved.
Dark Reader addon for webpages.  Pick any color you want (thousands of colors) for both background and text (background and foreground page elements).  Enable the preview mode on desktop for Firefox and Chrome addon, by clicking the dark reader addon settings, and somewhere there is a settings gear icon on the left of some window that pops up.  Clicking that allows you to choose the preview, or beta mode, to allow color options.  Not needed on mobile.
NoScript or EFF's privacy badger can block many scripts and websites that would load and track you, possibly halving page load time!
F-droid is a place to install open-source software for android, Antennapod, RethinkDNS, Fennec which is Firefox with about:config, lots of performance and other changes available, mozilla KB has a huge database of what most of the settings do.
Enjoy discussing firewall (blocks apps) and dns filters (redirects all dns requests om android, to your choice of dns, even if overridden).  RethinkDNS is my pick and I set it to use pi-hole, installed inside Ubuntu, which is inside Virtualbox, until I go to a website, nothing at all connects to any other server.  I also use NextDNS.io to do the same when away from home wi-fi or even cellular!  I can even tether from cellular to ANY device sharing via wi-fi, and block anything with dns set to NextDNS, regardless if the device allows changing dns.
You most likely have never needed a new phone (new hardware) to play most android games, using OpenGL, which hasn't seen updates in I think at least a decade or so, it's been quite a while.  Especially not what is on SoC GPU chips, it's lighter than regular openGL, which is already succeeded by Vulkan.  Look up videos for the games you want to play, and see how well a phone from 12 years ago will run them.
Look up n64, dolphin and ps1 emulation on hardware from over a decade ago on mobile processors, and you'll be surprised.
PC specs:
Linux enthusiast, LineageOS fan, WebOS, SymbianOS, MeegoOS was, backed by both Nokia and Intel, and e-ink displays.
Intel Xeon quad core, clocked down and peaks at around 0.97Ghz, even though it's set higher. I now have multiple profiles, one of which tops out at 0.53 GHz!
2 GB DDR3 clocked down to 800Mhz and undervolted 1.28v
GPU: GTX 960 (more than enough for games I play)
SSD: Samsung 840 232GB
HDD: 4 old spinners, less than 500GB each, using two.  One dedicated to Linux, open-source such as Ubuntu, Mint, or Fedora and the rest for downloads / games. I also use a third as an offline backup of Windows, because it sure can use it!
