Q. Odin Pro 800w and rtx 3080
Id be leaning towards no because its a shitty quad rail, it problably has a few more years of life left but dont think its suitable for a higher end gpu.
Psu market has gone to shit so i would reccomend buying a used 750/850w unit off your local used market (can be accessed via classifieds sites like fb marketplace), if youd like a reference as to how good the deals are then here in indo which is a developing country i can buy used 850w gold units like the superflower leadex gold for 55$ when new id be looking at 100$+, so id expect better deals in a more developed country
As for the gpu if you are buying that 3080 new i would reccomend a used 3090 over a new 3080 because it has lots and lots of vram, theres a bunch of em floating around 700$ on ebay, just gotta make sure you can return if faulty and you are completely safe buying used
If you are buying a used 3080 i would reccomend a used 6800xt or 6900xt instead as they have more vram than the 3080
