How do these antennas work?
11 minutes ago, Flux Azreal said:I know there's a lot of different antennas but I want to understand them more. I recently bought this network card with antennas
and I've been playing with the antennas for a bit and the results have been really weird and not consistant, I would get like 700mbps if i twist it a little or 300 if I twist it again, and I can't figure out a pattern. I don't know if it's public what kind of antennas they are, I presume there's some omnidirectional ones that don't care if if you twist it and directional ones that do. I'm not sure which these are and I can't find a manual thats relevant. Is there an optimal position of these? They can also bend like 45degrees or 90 and is there a way to optimize it for a certain position? I want to optimize it for the position of my modem
