RTX 3060 + 3600 with low usage
Solved by Crunchy Dragon,
Quotewhere the CPU stands at 40%-70% and the gpu stays on 60%-90%.
This doesn't sound like you're missing anything from the GPU, and looks to be a gaming system operating normally.
Ideally, you want your GPU usage to be as high as possible. This means nothing is holding your GPU back from performing to the best of its capability, and you're getting all the performance you can from it. This means the GPU isn't waiting for information from the CPU, as in the case of a CPU bottleneck where the CPU sits at 90-100% and the GPU is around 40-50%.
