Aura Sync/Creator compatible aRGB hub.
12 minutes ago, Cringe_Master245 said:I'm looking for an ASUS Aura Sync/Creator compatible aRGB hub, but ASUS is no longer supporting their ROG Terminal. I found a $20 USD Hub on Newegg, but it seems pretty sketchy because there are only 3 reviews and 4 ratings(4 1/2 stars as of the time that I am posting this). The other option was to use the controllers in ASUS' TUF 3 pack of fans and just look for a motherboard a couple aRGB headers, but then I would have to replace the fans on my AIO(360mm) and will probably need a more expensive "gaming" motherboard. If anyone has a solution/product that will work or that I missed, I'd appreciate the Help. I will also be open to any good 3rd party software.
TUF fans + controller: https://www.asus.com/us/motherboards-components/cooling/tuf-gaming/tuf-gaming-tf120-argb-fan-triple-fan-kit-with-argb-controller/
(I hope I am not breaking any rules by having links here)
asus got rid of it as it was costly and corsair was better. and alot of asus mb just added it in to the mb. and people started hacking it to make 100 led strips work.
