Help Appreciated- Pc restarts during games
Solved by An0maly_76,
8 minutes ago, Cheeseburgerr said:thank you for the detailed response, about to check cpu temps cause it is running a stock cooler, any suggestions for air coolers? im thinking noctua but havent check the size dimensions of the case and the cooler
Noctua or Scythe are good. I have a Mugen 5 on my 5900X and a Mugen 5S on a 3600X. The 5900X idles in the mid-high-30s and peaks in the low 70s. The 3600X peaks in the low-mid-60s.
DeepCool and Thermalright make some good coolers. The Peerless Assassin is a decent budget one, but I unboxed an Assassin, took one look at he bracket-upon-bracket mounting, stuffed it back in the box and ordered a Mugen 5S -- much easier to mount.
