Best silent 140mm rad fan quest :)
PDifolco
Hello mates
I currently use a pair of Arctic P14s on my 280mm CPU rad
They work fine temp wise, but when I need to push them above 1000rpm they make a kinda of hi pitched whine/resonance noise that I don't like at all...
This noise is relatively new, they're 18mo old maybe they kinda not age well, thinking to replace them
So what should I get ? I don't need iPPC style fans that can reach 3000rpm but with a turbine jet noise, what I'd need is some effective rad fan that's still silent (mostly) at 1200 to 1500rpm, which is the maximum I need to keep my CPU below 80c (assuming proper air pressure)
Are Noctuas AF14 good at that ? or BQ SW4s (non Pro) ? Other ?
System : AMD R9 5900X / Gigabyte X570 AORUS PRO/ 2x16GB Corsair Vengeance 3600CL18 ASUS TUF Gaming AMD Radeon RX 7900 XTX OC Edition GPU/ Phanteks P600S case /  Eisbaer 280mm AIO (with 2xArctic P14 fans) / 2TB Crucial T500  NVme + 2TB WD SN850 NVme + 4TB Toshiba X300 HDD drives/ Corsair RM850x PSU/  Alienware AW3420DW 34" 120Hz 3440x1440p monitor / Logitech G915TKL keyboard (wireless) / Logitech G PRO X Superlight mouse / Audeze Maxwell headphones
If you want quiet performance cooling, Noctua is usually the brand of choice
Looking at the product page, the Noctua AF14 will be only 19.2 Db if you use the included low noise adaptor. Should be plenty quiet enough.
I might be experienced, but I'm human and I do make mistakes. Expand for common PC building advice, a short bio and a list of my components and other tech. I edit my messages after sending them alot, please refresh before posting your reply. Please try to be clear and specific, you'll get a better answer. Please remember to mark solutions once you have the information you need.
Common build advice: 1) Buy the cheapest (well reviewed) motherboard that has the features you need. Paying more typically only gets you features you won’t use. 2) only get as much RAM as you need, getting more won’t (typically) make your PC faster. 3) While I recommend getting an NVMe drive, you don’t need to splurge for an expensive drive with DRam cache, DRamless drives are fine for gamers. 4) paying for looks is fine, just don’t break the bank. 5) Tower coolers are usually good enough, unless you go top tier Intel or plan on OCing. 6) OCing is a dead meme, you probably shouldn’t bother. 7) "Bottlenecks" rarely matter and "Future-proofing" is a myth. 8) AIOs don't noticably improve performance past 240mm.
useful websiteshttps://www.productchart.com - helps compare monitors, https://uk.pcpartpicker.com - makes designing a PC easier.
He/Him
I'm a PhD student working in the fields of reinforcement learning and traffic control. PCs are one of my hobbies and I've built many PCs and performed upgrades on a few laptops (for myself, friends and family). My personal computers include 3 windows (10/11) machines and a TrueNAS server (and I'm looking to move to dual booting Linux Mint on my main machine in future). While I believe I have an decent amount of experience in spec’ing, building and troubleshooting computers, keep in mind I'm not an expert or a professional and I make mistakes.
Favourite Games of all time: World of Tanks, Runescape, Subnautica, Metroid (Fusion and Dread), Spyro: Year of the Dragon (Original and Reignited Trilogy), Crash Bash, Mario Kart Wii
Main PC: https://uk.pcpartpicker.com/user/will0hlep/saved/NByp3C
Secondary PC: https://uk.pcpartpicker.com/user/will0hlep/saved/cc9K7P
TrueNAS Server: https://uk.pcpartpicker.com/user/will0hlep/saved/m37w3C
Laptop: 13.4" ASUS GZ301ZE ROG Flow Z13, WUXGA 120Hz, i9 12900H, 16GB DDR5, 1TB NVMe SSD, 4GB RTX 3050 Ti, TB4, Win11 Home, Used with: 2*ThinkPad Universal Thunderbolt 4 Dock, Logitech G603, Logitech G502 Hero, Logitech K120, Logitech G915 TKL, Xbox Elite Wireless Controller Series 2, Logitech G PRO X Gaming-Headset (with Blue Icepop in Black), {specs to be updated: two monitors}
Other: LTT Screwdriver, LTT Stubby Screwdriver, IFIXIT Pro Tech Toolkit, Playstation 1 SCPH-102, Playstation 2 SCPH-30003, Gameboy Micro Silver OXY-001, Nintendo Wii U WUP-001(03), Playstation 4 CUH-1116A, Nintendo Switch OLED HEG-001, Yamaha RX-A4A Black AV Receiver, Monitor Audio Radius (4*90s, 1*200s, 2*270s, 1*380s), TP-Link TL-SG105-M2, Netgear GS308, IPhone 14 Pro Max 128GB Space Black, Secretlab TITAN Evo (Black SoftWeave Plus Fabric), 2*CyberPower BR1200ELCD-UK BRICs Series, Samsung 40" ES6800 Series 6 SMART 3D FHD LED TV, UGREEN USB 3.2 Gen 2 10Gbps M.2 NVMe SSD Enclosure, SABRENT 3.5" SATA drive docking station
29 minutes ago, Dogzilla07 said:
@will0hlepcomparing using official numbers is useless
@PDifolco
Well, interesting
I'm kinda hesitating even more now, my P14s top the charts and alternatives are 35EUR+ to maybe 8EUR for the P14 (got white version...) 😮
3 hours ago, PDifolco said:
Well, interesting
Can u check if the noise goes away if your P14 speed is fixed above 1250 RPM ?
Though if it's a new noise, it's likely they're just at the end of their life 😞
U could try and risk it with the new EK FPT fans (should show up in other shops/amazon 1st/2nd week of January now)
https://www.ekwb.com/shop/radiators-fans/fans/140mm
Arctic fans are known to make that nose at that rpm... at lest the p do. they sell more expensive fans that i think fix that problem thow.
Edited by thrasher_565
Corsair Lian Li Bykski Barrow thermaltake nzxt aquacomputer 5v argb pin out guide + argb info
5v device to 12v mb header
Odds and Sods Argb Rgb Links
No noise is there above 1000 rpm, but tightening up screws reduced the noise   🙂
Which ones ? New are mostly RGB versions
21 minutes ago, Dogzilla07 said:
Ok these are EK fans didn't see many reviews on them.. how do they perform ?
Unknown, they at pre-order stages, launching next week and the week after that. Oh and, yeah I'm blind, I didn't noticed the reply chain xD @thrasher_565 was referencing the ARGB ones from Arctic, which like the white EK one can be kept with RGB shut-off, and they still look very nice in white.
Get a 3-pack of the P14 argb versions - supposedly, they don't have that noise issue at 1000rpm.
the artic fans that are not in the pack are better but cost like 2x more at lest thats what others were saying?
the noise issue is fix by them using a ring around the fan blades (aka noiseblocker style)
Ryzen 5700x + EK Supremacy D-RGB | 2x8 GB DDR4 Klevv 3200 MT/s | MSI B550M Mortar | Palit 3070 GamingPro LHR + Bykski N-PT3070PRO-X | Corsair RM750 | Alphacool EPDM + QDC | Aquacomputer Quadro + HighFlow2 | EK D5 XTOP | Freezemod 360 30mm rad + Barrow Dabel-20b 360 20mm | Barrow & Freezemod fittings | Corsair 5000D Airflow
Audio: beyerdynamic DT 900 Pro X + iFi ZEN Air DAC + Razer Seiren Mini
Ok may try that, they're still at a decent price, though wayyy more expensive than base version, 20eur to 8
And I need only 2 damn😁
