help Will VRM Heatsink melt my cables?
Solved by Godlygamer23,
38 minutes ago, erenthegod said:Okay, then, thank you so much for the explanation.
The insulation(including the sleeving) can get to around 80 degrees C before melting. So you should be good. For future, I would keep wires away from any sharp metal edges. Over time, the wire insulation could get cut through, and the wire inside could short out against the metal. In your photo, you should be okay because the sleeving is against the heatsink, not the actual wire.
