RTX 2070 Super to RTX 3070 not TI worth it?
GazCBG
Hi,
I currently got a RTX 2070 Super and looking to upgrade to a RTX 3070 (not ti) and would like to know is it worth the upgrade?
It will be used for gaming and gernel usage.
Below I have listed my PSU, Motherboard and CPU:
PSU: Be Quiet Straight Power 11 750w
Motherboard: MSI X570-A Pro
CPU: AMD Ryzen 5 3600
Regards,
Gaz
I would be saving up a bit more to go for something else. The 3070 is a bit of an uplift, yeah, but it's not massive. There's not a ton that a 3070 can do that a 2070S can't. Personally I'd want at least a 3070 Ti for an upgrade, and a 3080 or higher would be preferred (including all AMD equivalents). If you snag a really good deal on one used, say $300-350 for a 3070 yeah go for it, it's a pretty nice upgrade for not that much more and 3070s are the highest end GPU from Nvidia I'd personally feel comfortable buying used (GDDR6X can degrade a bit from mining, and most 3070 Tis and higher I would assume were used for mining and I wouldn't trust the long term reliability of those cards). Plus, next gen GPUs are right around the corner, so it's probably worth waiting and getting something like a 7700 XT or RTX 4060 Ti when it releases.
Thanks for the replies, this is what I thought it wasn't worth it, just wanted it confirmed.
I will look for a 3070 Ti.
12 minutes ago, jaslion said:
Not really. The 3070 is a 2080 replacement and a 2070 super already comes close to those levels.
The 3070 was the 2080 Ti replacement, the 3060 Ti was the 2080 replacement.
Your conclusion is still right, but there is more of a gap than you gave credit for.
Yup true but doesnt the 2080ti still perform 10% better than a 3070?
I looked it up again and my tought of about a 15% difference between the 2070s and 3070 is true so not a good upgrade that you might often not even notice
No, the 2080 Ti performs about the same as the 3070 which is ~10% better than the 3060 Ti.
Average Gaming FPS FPS 2560x1440
