Pc won't post with gpu in top slot
Solved by BookofNeat,
1 minute ago, zdemigod said:Really? I thought the top slot was the only 16x lanes and the bottom is only 4x. I have spent the entire day on this so I will sleep and try your recommendations tomorrow. but IF no massive performance hit will be had by keeping the bottom slot I might as well just keep it there.
Absolutely! Get some rest and try and see how it works. There should be absolutely no drawback in performance from using that PCIe slot if ASUS' specifications are correct. Worst comes to pass, you'll just have a weird-looking interior to the desktop. Nothing to worry about and definitely not worth just throwing away, just don't let frustration ruin your excitement for gaming.
Sleep well and I hope to hear from you later! (づ。◕‿‿◕。)づ
