Undervolt issues - ThrottleStop
Solved by unclewebb,
3 hours ago, zizou said:PL 2" is flashing red
Your CPU has a 45W TDP rating. Typical settings are PL1 is set to 45W and PL2 is set to 60W. ThrottleStop shows that both of your power limits are only set to 24W. That is the cause of your power limit throttling.
If those power limits cause overheating, fix the cooling problem.
I would also set IccMax for both the core and the cache to the max, 255.75. That helps avoid EDP throttling.
