Can I use a water driven air cooler in same room as PC?
Solved by BobVonBob,
Definitely don't put it right next to the PC, and if you already have a high baseline humidity in the room an evaporative cooler can push it into ranges you wouldn't want to keep your PC at long term, but there shouldn't be too much of an issue otherwise. You're going to get uncomfortable in the humidity and turn off the cooler before it poses a serious risk of harm to your computer.
Featured Topics
Juan Sulthon ·
Posted in Troubleshooting0 -
4
Justbon321 ·
Posted in Troubleshooting5 -
Tamgam12 ·
Posted in Troubleshooting6 -
Justbon321 ·
Posted in Troubleshooting1 -
SandwichMake ·
Posted in Phones and Tablets2 -
3
4
play_circle_filled
Latest From Linus Tech Tips:
iPhones Are Undeleting Nudes?? - WAN Show May 17, 2024
play_circle_filled
Latest From Tech Quickie:
Ethernet Is Named After Something Really Dumb (and other tech stories)
