Initial power to PSU causes UPS to trip
The Corsair psu has big capacitors inside and a high inrush current as they charge up at cold power on - power supplies reduce this inrush current by placing a resistor in series with the input that lowers the resistance as it heats up from the current passing through it, and after a few seconds a mechanical relay in the power supply shorts out (removes it from circuit) that resistor to increase the power supply efficiency and reduce heat produced.
The draw at startup can be significantly higher with simulated sine wave or square wave outputs (if the USP provides the power from internal batteries through an inverter)
The UPS may see that high inrush current as too high power draw and turn off to protect itself.
Fix ... other than replacing that resistor inside the psu with a bigger one to slow the startup, I don't see what you could do...
