damage Would Your CPU Be Permanently Affected if it Ran at 99c Under Load... For 3 Years?
Solved by BiotechBen,
I mean, it's still technically in spec for the CPU, Ryzen 2000/3000 series generally had a TJmax of a out 105C, so the best analogy I can give you is driving a manual and revving our to the red line in every shift; technically within acceptable operating conditions, but mechanically abusive. Heat as a result of voltage does degrade ICs so it may have had some excessive premature wear, but probably taking it from 14 yrs of service to like 13.5.
