will ryzen 5 3600 bottleneck a 6750 xt?
Shinra
Recently i've been having problems with my gpu artifacting, doing stuff it shouldn't and the list goes on, and i don't wanna fuss with it anymore so i am thinking of upgrading to a radeon 6750 XT.
So i've been wondering will a ryzen 5 3600 oc'd to 4.45GHz 1.378 volts bottlneck that gpu when playing games on 1080p?
A friend told me it would bottleneck it quite a lot but you know i like to get educated by more people on the manner.
A Ryzen 5 3600 is a pretty decent CPU for modern games, you get pretty great performance at 144Hz.
Friend of mine has a 6700XT on his 3600 (not overclocked) and his experience is top notch.
Primary PC:
1440p no. 1080p yes. As a user of a 3600 paired with a 5700XT.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 30+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - HyperX Alloy Origins Core (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Arcadyan ISP router - 35/5 Mbps vDSL
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
okay, and do you know how much will it be bottlenecked?
Dont worry about it too much, its not that much. You could always upgrade to a 5600x-5900x later if you need a bit more but overall you arent a world top gamer and wont notice the difference between 160 fps and 150 FPS, and it really only matters if you play first person shooter games
In what? Which games? How fast a monitor?
Also, the 6750 is just an overclocekd 6700, no sense paying more than for a 6700.
Mostly in games. from the witcher 3, doom eternal and many more like these. i have a 144hz monitor
alright, thank you for your time.
3 hours ago, Shinra said:
it only matters if u start noticing it.
But in theory if u were to play on low-medium in a competitive title the 3600x will pump out more than 144hz anyway.
For AAA titles most of the bottleneck you won't notice.
for the drops you notice on 1080p, say medium, vs a 12700k with ddr5 or 5800x3d,i'd say the bottleneck is 25% in very specific scenarios, it's a really rough guess since the most recent benchmarks either don't include the newest cpus or the older ones.
and you can upgrade to a 5800x3d anytime if u wanted to
5950x 1.33v 5.05 4.5 88C 195w ll R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-24-2T (zen trfc)  1.45v 45C 1.15v soc ll 6950xt gaming x trio 325w 60C ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll 6x nf12/14 ippc fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll AW3423DW
9900k 1.36v 5.1avx 4.9ring 85C 195w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5500 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-30-280-20 ddr3666bdie 1.45v 45C 1.22sa/1.18 io  ll EVGA 30 non90 tie ftw3 1920//10000 0.85v 300w 71C ll  6x nf14 ippc 2000rpm ll 500gb nvme 970 evo ll l sandisk 4tb sata ssd +4tb exssd backup ll 2x 500gb samsung 970 evo raid 0 llCorsair graphite 780T ll EVGA P2 1200w ll w10p ll NEC PA241w ll pa32ucg-k
prebuilt 5800 stock ll 2x8gb ddr4 cl17 3466 ll oem 3080 0.85v 1890//10000 290w 74C ll 27gl850b ll pa272w ll w11
HardwareUnboxed a.k.a Techspot tested with RX 6800 which slightly faster than RX 6750XT
https://www.techspot.com/review/2185-amd-zen-3-ryzen-5600-versus/
With those you're more than ok.
Where a stronger CPU would matter would be competitive multilayer and multitasking on multiple monitors.
You shouldn’t cut down on your on your cpu if your going to buy a high end gpu but if it runs fluently then go for it.
