What GPU should my monitors be using?
Both of your monitors should be plugged into your 1650, this will allow for optimal graphics settings.
Your lag may be coming from your encoding. If it is bad, you could try switch between software and NVENC encoding.
Your 1650 should support NVENC, but you may not be happy with the quality. Its worth trying though!
Also if you can, you should be hardwired. WiFi is not good for streaming.
Featured Topics
Anonymous1234 ·
Posted in Troubleshooting1 -
DragonTamer1 ·
Posted in Graphics Cards2 -
Chida_up ·
Posted in CPUs, Motherboards, and Memory5 -
5
Hendricks3 ·
Posted in Phones and Tablets4 -
Anderson welch ·
Posted in Networking7 -
Gat Pelsinger ·
Posted in Windows2 -
7
8
