KZ ZSN Pro X, cracked housing, pls help
29 minutes ago, Hassan170 said:
So I accidentally stepped on left IEM while it was in pants, omw to toilet.
And when I took it out a few hours later, turns out the housing of the connection point is cracked/deformed.
Such that I can't plug in my stock cable or the AZ09 Bluetooth adapter that I was using when I stepped on it.
My question is, is the damage repairable? Cuz considering how tightly packed all the components are I would not think so.
it looks for me like the contacts are gone... could you repair them? Probably. Would it cost more than new ones? Most likely… A new pair should cost you around 20 $ so…
Or look for something else that uses the C-Pin, KBear and CCA use them for some IEMs as well
Is the AZ09 fine? I have always seen the C-Pin connector as pretty fragile
