Recommendation for a monitor?
CMDCDY
Looking for recommendations for a 27+ inch 1440p, 144+hz monitor, preferably under 350 (US), although I can do a bit more. Thanks for your help !
What is more important to you, visual quality of the panel or specs (refresh rate...)?
The LG 27GL83A-B is currently a great option for around $300. But be aware that this monitor doesn't support a wide color gamut. If gaming is the main use, then this shouldn't be a problem though.
For a wider color gamut, the Gigabyte M27Q is another good option around $330, but with the tradeoff of the suboptimal BGR pixel layout, which can (doesn't mean it will) result in worse text clarity.
If someone did not use reason to reach their conclusion in the first place, you cannot use reason to convince them otherwise.
Specs, it’s mainly for gaming, but both hold value
