1080p 60hz with a 5800x and 3080?
Solved by Shimejii,
59 minutes ago, MasteredDelta said:My friend tells me that you really only need a 1080p 60hz display. I tell him that I have a 3080 and he replies with "and". And now I'm confused whether to save money and get like no fps or spend 2x as much and actually get the fps I paid for.
Your friend is an idiot and you should no longer take any tech advice from him. 1440p 165hz or 240hz if you play First person shooters. It makes a MASSIVE difference, and anyone that says "it doesnt" is simply wrong.
Its worth it to save up and get a good quality monitor
