Need help figuring out whats wrong. Psu or gpu?
On 3/24/2022 at 4:53 PM, Shadowpaw said:Hopefully it's just gpu and they have a replacement already sent when you get back. I've had a psu last over 10yr without issues and that's back when I played WoW every free moment. If you don't have a multimeter or are not comfortable testing a live wire while it's running to see what the psu is sending out you could also maybe get one of those 2xmolex to 6/8pin wires if they say it wasn't the gpu and test that. It's not ideal but they only a couple bucks and if the pcie power is having issues then this way you could test getting power a different route from a failing psu to get you by until you can get another.
In case you were curious on an update. I changed to a new and bigger wattage psu and the problem is now fully gone. Card runs fine maybe even abit better then what it used to
