Do i need headphone amplifier
Go to solution Solved by Tusk2435,
3 minutes ago, zmrzlapka said:
Hello so i wonna buy beyerdynamic dt-990 PRO 250ohm and i wonder if i need headphone amplifier for it ?
if i need heaphone amplifier, I dont really know which heaphone amplifier i need for 250ohm
if you can pls help me which headphone amplifiers are good in my budget bcs im tottaly lost in it 😅
my budget is somewhere around 120€
Thank you 😀
With 250Ohms you really need an amplifier; without it, your PC is just not going to play loud enough. There are also DAC amp combos, which will bypass the motherboard DAC, but you don't really need another DAC, and you could always get a separate one down the line.
In that budget there are a lot of really good choices: (added audiosciencereview.com review link)
- JDS Labs Atom Amp+, one of the best performing amps for the cost, punching well above its price range. My best recommendation. ASR
- Schiit has the Magni and Vali (if you're into cool tubes and can stretch the budget a little bit). Both only amps; I can strongly recommend the Magni. ASR
- Topping NX4 DSD, DAC amp combo; performs wonderfully and is also portable. ASR
- Fiio has the E10k andd K3s, both DAC amp combos; they measure worse than others, but still great choices for the price. Fiio has also portable units, but they don't perform as well as their desktop counterparts, at least power-wise.
- Audioquest Dragonfly, very well-known tiny DAC amp combo, measures pretty good but won't be driving high-impedance headphones as well as other more beefy units.
- iFi Nano iDSD, performs ok in measurements. ASR
- Audioengine D1, though there's no technical measurements around that I could find.
For all of these (or others you'll take into consideration), you should look for technical reviews, going really in-depth in noise, distortion, power, etc.
Thank you 😀
https://linustechtips.com/topic/1413053-do-i-need-headphone-amplifier/
Thank you 😀
DESKTOP PC - CPU-Z VALID | i5 4690K @ 4.70 GHz | 47 X 100.2 MHz | ASUS Z97 Pro Gamer | Enermax Liqmax II 240mm | EVGA GTX 1070Ti OC'd
HOME SERVER | HP ProLiant DL380 G7 | 2x Intel Xeon X5650 | 36GB DDR3 RDIMM | 5x 4TB LFF Seagate Constellation 7.2K | Curcial MX500 250GB | Ubuntu Server 20.04
6 minutes ago, pas008 said:
if Asus ROG Strix X570-F Gaming is the motherboard you have I'd say try that first
seems to have an amp so try that first
All motherboards have a realtek amp/DAC or something equivalent. And all of them aren't always good.
PM/DM me if you have any questions about audio.
▼My PC specs & audio gear▼
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧▼Current Audio Setup▼🎧
HifiMan Ananda Nano, HE400se, X2HR
Soundblaster AE-9 Soundcard
AKG P420 Mic
â–¼Other peripheralsâ–¼
Monitor > Samsung Odyssey OLED G9
Keyboard > Keychron Q3 HE TKL
Mouse > Logitech G Pro 2 Lightspeed
Mousepad > X-Gamer XG++ XXL mousepad
Read this post if you want a "gaming" headset ;)
always hence word try
as a person that has been through dacs amps and headphones, still own quite a few,
seems like anything after haswell days they did up mobo sound imho, just typical interference/usb feedback on some
i thought my z87ws sound was just as great as o2 combo until i added 3rd gpu
If you'll be getting the DT990 and your motherboard audio is not powerfull enough, don't get a analytical dac/amp like the Fiio otherwise you'll suffer from strong treble/sibilance. In the past, I had the DT880 250ohm to use with Fiio K5 Pro and there was a massive amount of ssssibilance and at some point, I couldn't bear it anymore. Now almost a year later, having the 2 dac/amps (in my sig), sibilance is no longer an issue in any headphone.
@rice guruwould be probably be recommending the Monolit Liquid Spark to tame the treble. He has the DT990 too. Analytical dac/amps are not really fun.
DAC/AMPs:
Klipsch Heritage Headphone Amplifier
Headphones: Klipsch Heritage HP-3 Walnut, Meze 109 Pro, Beyerdynamic Amiron Home, Amiron Wireless Copper, Tygr 300R, DT880 600ohm Manufaktur, T90, Fidelio X2HR
CPU: Intel 4770, GPU: Asus RTX3080 TUF Gaming OC, Mobo: MSI Z87-G45, RAM: DDR3 16GB G.Skill, PC Case: Fractal Design R4 Black non-iglass, Monitor: BenQ GW2280
